Not original fit then.It a lead acid battery
Yes.Photo of charger switch is that in the correct position to charge an lead acid battery View attachment 357601
YesThanks for that so if I purchase a gel battery I’m assuming I will have to slide switch
The battery may have been left discharged before you bought it, especially if you brought from a dealer. The original battery would have been Gel.I’ve had the van since last July it’s been over to Belgium for two weeks and has been used four or five times since then probably adding up to another couple of weeks last used Christmas for two days I had a solar panel fitted on purchase which charges both batteries (engine and leisure) I noticed last week the battery reading on leisure was on the low side so plugged in van to charge battery I’ve not used it off grid so haven’t flattened battery
I did have the heating running for several hours (12v fan) but was always ehu
No because it is only a trickle charge to the starter battery.Just asking a basic question.... Does it make a difference to the Elektroblock if the van and hab batteries are different ie LA and Gel?
Thanks.
