JeanLuc
Thanks, everybody.
I couldn't see a 50 amp fuse anywhere else - nothing in the battery area. Photos show whats there.
I looked again at your photos of the EBL where you state the 50 amp fuse is apparent, but I cannot see one. In the most recent post you state as above 'anywhere else'. Have you found a 50 amp fuse somewhere then and if so, where is it?
You could fit a lead-acid battery again, or a gel that will have greater discharge resilience. If you plan to go long-terming and cannot fit a second battery, I would go for a gel, rather than a lead-acid. If you can get two batteries in, then either will do but the gel will again have greater discharge ability - i.e. you can risk running it lower than you can with a lead-acid (roughly 75-80% versus 50% discharge level: gel versus lead-acid).
Regarding the live lead, it is true that both the starter and habitation batteries +ve are connected to the EBL. However, there should be a relay within the EBL that disconnects them when the engine is not running. For safety, you need to find the main fuse (either 30 amp or 50 amp) that is in the +ve line from the habitation battery to the EBL. It is shown in the circuit diagram and must be there somewhere.
As I mentioned before, I would email Udo Lang and ask for manuals and advice.
