jo10000_6
Catching up on a previous thread I may have gone about this in totally the wrong way …..but it seemed correct at the time !
I've had the motorhome a year and have primarily stayed on sites but this year we plan to be on less EHU so I've been carrying out some test to see how long my 1 battery will last and on paper its great.
In practice not so much
So, my Hymer B544 isn’t power hungry.
I have calculated the following as the primarily power draws :-
TV – 3 Amps
1 Bench Seat Fluorescent Strip – 13W = 1.083 Amp
1 Kitchen Area Fluorescent Strip – 11W = 0.92 Amp
Couple of LED Spots 0.125 Amps x 2
Some Festoons – Not a Lot
Bathroom LEDS – Not a lot and due to intermittent use not concerning.
Water Pump = 5 Amps per Hour – Intermittent use as we know
Truma Vent System – Book seems to suggest 0.2-1.0 Amps Per Hour which seems low when I read about how much other people use but I’m sure I’ve read the book right.
Ariel Amplifier thing – not a lot
Boiler – Not sure TBH
Anyway to get an idea of how long I can last on 1 battery – on paper I calculated I could have the following :-
2.5 Hours TV – 7.5 Amps
4 Hours 2 x Fluorescent Lights – 8 Amps
Water Pump – 10 Mins a Day – 0.835 Amps
Bathroom Lights 10 Mins a Day – 0.14 Amps
Don’t really use the vent system but interested if that’s sounds about right.
Anyway with some festoons and some spot LEDs it came out at approx 17.69 so let’s say 18 Amps a day for the above.
I calculated 2.5 Days and the battery would be at 65% so keeping on the right side of the discharge.
Last week did some experiments TV first then lights.
The figures don’t read well.
I left the TV on for 8 Hours and got to 50% Discharged – so 55 Amps used for what should be 24 – 30 would have been ok but half of the battery - I’m confused.
I left the two strips lights on today for 5 hours and discharged to 60% left – the lights are 2 Amps total per hour – but I’ve used approx. 44 Amps.
Battery 10 months old approx. 12 weekend trips on EHU with a few intelligent charge re-charges as mine is an old charging system and I didn’t want to rely on it for maintaining the battery.
Now I understand perhaps you lose some efficiency in cold weather (10 % mentioned) but this is more than this.
I’m sure I don’t have a drain (no alarm) there’s nothing fancy on the motorhome and all I can think off is battery is duff.
I may have been measuring the battery at the wrong times to get accurate readings but wasn't sure when else to do it and reading a previous thread has brought this to my attention.
Any comments appreciated.
Jo
TV – 3 Amps
Jo
