Led.com drl for Fiat X250
Rugby
Elddis Autoquest 185
Since2012
Hi all,
Anyone fitted these? Thinking of getting some for mine and wondered if anyone already done this and could comment on quality and fit. Currently on sale at about £118 delivered, don't know if any discount codes available
Geoff
I bought a pair of LED DRLs to replace the standard bulbs in our 2015 A class Hymer. Got them from Halfords for about £20 for the pair. Work very well. But best to check if they will affect your Canbus. But £118 sounds a lot unless you are replacing the whole headlight unit, which should not be necessary.
Led daylight running lights (DRL) These fit in one of the recesses in front bumper. As you know you can't switch side lights in alone on this model
I bought and fitted a set from another Funster that had bought a set but never got around to fitting them before changing motorhomes.
They are good quality and are easy to fit.
I fitted them because although we are big and white it does no harm to be that bit more visable in daytime.
Fitting instructions are on the Ledcom if you want to look at what's involved in fitting them.
Paul
Thanks, looked easy to fit and like you I like drl's , think you cannot be too visible these days.
Regards
Geoff
Fitted some a few years ago and happy with them. A side benefit is that they appear to be an acceptable substitute for dipped headlights in countries that call for lights to be on in daytime.
Just a tip - test them before replacing the nearside headlamp unit............................................. The blade connector hadn't quite, erm, connected.
