It comes with a Mains adapter and a 12V lead with cigarette lighter plug and can also be plugged into a solar panelneeds 240 or 15 volt to recharge?
Good to plug in a PA at Stratfordneeds 240 or 15 volt to recharge?
Its about 27ah by my calculations so for half that price you could have nearly double the capacity and a safer battery technology, the only downside would be it would be heavier.Wondering about one of these to boost our power when away in the winter
We don’t have a sensible place for a second battery we could put one in the garage, but too far away from charger routing cabling would be a nightmare. We usually manage ok, but dread the battery running low and not being able to power John’s CPAP have considered lithium, but am worried about their performance in the cold weather.Its about 27ah by my calculations so for half that price you could have nearly double the capacity and a safer battery technology, the only downside would be it would be heavier.
Unless you like to sit in your van with the inside temperature well below zero it won't be a problem.dread the battery running low and not being able to power John’s CPAP have considered lithium, but am worried about their performance in the cold weather.
The only spec I see says, "Capacity: 325Wh Built in battery technology: 100% high quality lithium battery cells" so it won't be LiFePO4Is it a Lithium battery? Can't seem to find any specs on it? Who's the manufacturer?
Being able to move easily to another van is a plus point for us less technical people like me.I met a guy on a site a couple of months ago who swears by these battery packs, he had just sold his original one and got a more powerful one.
He said because they are portable you can take in the house to charge, use solar to charge when in the van, if you change your van no messing about removing equipment etc. He was using it to watch television and charge stuff as we were speaking he said.
battery isn't within the motorhome body. rather in a box undernath the van but accessed from inside. the van is insulated well, even ha a heater oulet in the casette compartment! so would hope the battery compartment is suitable insulated, think I really need to put a thermometer in there in the winter to check.Unless you like to sit in your van with the inside temperature well below zero it won't be a problem.
You just need to make sure they are not charged below zero.
