Isotherm fridge
sabrina14
auto roller 747
Does anyone know what’s happened to our fridge. It’s not working! The fridge is flashing lights. We’ve tried to hold down the button for 3 seconds and set the temp. It will not stay on! What do the flashing lights mean? Is the fridge faulty?
it’s in a auto roller motorhome 20 plate.
thanks
Any help?
thanks
which power source are you attempting to use
That one is a compressor fridge with I think auto switching for 240v/12v operation.
I would try switching between 240v & 12v and see if it does it on both power sources, if only on one it could be low voltage.
If you can't switch it manually you can turn of the mains in the van or unplug the EHU and it should switch to 12v.
It says the OP has an Autoroller 747 they are equipped with a 3 way fridge as far as I'm aware
You could be right - I saw the diagram and made an assumption. But the diagram didn't come from the OP who could usefully add some clarity.
