Gorse Hill
Any suggestions on a good battery monitor LennyAfter fitting a battery monitor I was surprised to find I was using 32a/h a day before my estimate was around 20a/h.
TIA
I have the Victron BM700, found the display a bit small so ended up getting the Bluetooth dongle for it.Any suggestions on a good battery monitor Lenny
TIA
I'd second the Victron BMV-700 (with a BT dongle) https://www.victronenergy.com/battery-monitors/bmv-700I have the Victron BM700, found the display a bit small so ended up getting the Bluetooth dongle for it.
In the last van I fitted a cheap £20 eBay it did the job but I do prefer the Victron dispite the vast extra cost.
With the Victron Bluetooth dongle you can bring up your history and see use since last full charge number of full charge cycles, fun if you are a techie.
I too have a 3.5 T motorhome. I laso have 250W of solar and 2 x 100 HA batteries. If I was in your position and had a lot of money I would put up a shed load of solar and a Gel battery. I would not worry about being a few kilos over weight. I suspect I and many others are over the limit.With modern motorhomes often having little payload I wonder if B2B is a better bet than the weight of an extra battery. The B2B will fit in a much smaller space and weigh very little, of course it will be dearer than a second battery. Having lost my C licence due to Glaucoma I have had to down rate to 3500kg so am conscious of extra weight.
I suppose it depends on how many Ampere Hours you have stored. One battery charged at 14.4volts by the B2B or two batteries charged at 13.8volts directly from the alternater.
At the moment I just have a single 110Ah battery with a 40Watt portable solar, at least I can point that at the sun.
Not sure that is strictly true. I believe the driving license relates to the registered maximum weight of the vehicle, not it’s weight in use. You can not drive a vehicle with a registered maximum weight of 3700kg without a C license, even if the actual weight in use is less than 3500kg, so why should the converse be different. I am not suggesting anyone should drive an overloaded 3500kg vehicle but I believe the offence would be overloading not driving without a license.Well if you do not have a C licence you are effectively driving without a licence. That would interest the insurance company.
How long off grid is totally dependant on your power usage and time of year. At a guess with a decent MPPT regulator you would probably be OK from May until September with reasonable sunshine you could manage around 10 days but a few rainy days would halve that.I haven’t started upgrading my system yet, I had grand ideas but will have to scale back for various reasons, I presently have 100w solar with the crappiest cheapest pwm you’ve ever seen and TWO 110ah Gels. For now I’m thinking of upgrading the controller to a MPPT victron or votronic and getting a B2B. Opinions welcome. How long can I stay off grid with that, with average use and would the gels support a 2000w inverter in case I’d like a coffee?
Hi Lenny, the 2000w is a guesstimate, the machine is 1400w so I’m probably overthinking it, and like all things coffee related it’s a luxury not a necessity! I never worried about all this with my elddis with 100w solar a cheap pwm and two 110 wet batteries, maybe because the set up was all new? I just cracked on and never hooked up unless I had to, then again I didn’t have a coffee machine or inverter! I guess I just don’t understand how much better my gels are than wets. Perhaps I’m just overthinking the whole thing.How long off grid is totally dependant on your power usage and time of year. At a guess with a decent MPPT regulator you would probably be OK from May until September with reasonable sunshine you could manage around 10 days but a few rainy days would halve that.
Outside of those months you are going to need a lot more solar even 600 watts won't be enough mid winter.
A 2000 watt inverter running at full chat will your batteries quite quickly, if you need that much power double your battery bank, also 200 watts of solar will never recharge then them with that sort of power use.
But if you are just going to use it for a few minutes a day for a coffee machine it will only have a minor impact on battery life.
I have a Votronic MPP 350 with remote control/display that I am no longer using. I could be persuaded to part with it. PM me if you are interested.I haven’t started upgrading my system yet, I had grand ideas but will have to scale back for various reasons, I presently have 100w solar with the crappiest cheapest pwm you’ve ever seen and TWO 110ah Gels. For now I’m thinking of upgrading the controller to a MPPT victron or votronic and getting a B2B. Opinions welcome. How long can I stay off grid with that, with average use and would the gels support a 2000w inverter in case I’d like a coffee?
Wow where do all those wires go? Shouldn’t there be a plug of some sorts on the display cable. I guess the votronic has the starter trickle charge option but is more tricky to install, where as the victron is simple but no starter facility, is this correct?I have a Votronic MPP 350 with remote control/display that I am no longer using. I could be persuaded to part with it. PM me if you are interested.
It is easier than it looks. There is a plug on the display cable but it is clear plastic and didn’t show up in the original picture. The chunky cable is a plug in connection for a schaudt EBL. The other one is a temperature sensor for the battery. I think the temperature sensor and second battery connections are optional.Wow where do all those wires go? Shouldn’t there be a plug of some sorts on the display cable. I guess the votronic has the starter trickle charge option but is more tricky to install, where as the victron is simple but no starter facility, is this correct?
No it's easy you just need a single wire to the starter battery positive.I guess the votronic has the starter trickle charge option but is more tricky to install,
Well that’s the controller sortedI have a Votronic MPP 350 with remote control/display that I am no longer using. I could be persuaded to part with it. PM me if you are interested.
Sadly the main downside of gels is they are not so good at very high amps. It's best to stick to the limit of C/5, where C is the battery Ah capacity - so for you it's 220/5 = 44 amps. If you consider that 1200W requires 100 amps, you can see the problem. This is about the only situation where re-badged starter batteries are better than proper leisure batteries.the 2000w is a guesstimate, the machine is 1400w so I’m probably overthinking it, and like all things coffee related it’s a luxury not a necessity! I never worried about all this with my elddis with 100w solar a cheap pwm and two 110 wet batteries, maybe because the set up was all new? I just cracked on and never hooked up unless I had to, then again I didn’t have a coffee machine or inverter! I guess I just don’t understand how much better my gels are than wets. Perhaps I’m just overthinking the whole thing
Thanks for that, and here’s me all smug cos I thought gels were the bees knees (apart from Lithium of course) autorouter I’ve read read quite a few of your posts as well as Lenny HB and Raul on various things electrical and I’m blown away with your knowledge. Unfortunately when I’m reading these posts all I see isSadly the main downside of gels is they are not so good at very high amps. It's best to stick to the limit of C/5, where C is the battery Ah capacity - so for you it's 220/5 = 44 amps. If you consider that 1200W requires 100 amps, you can see the problem. This is about the only situation where re-badged starter batteries are better than proper leisure batteries.
Reckon that’s top advice.First step is to boost your storage capacity by adding another one or two batteries, no pont in having better chagre rates if you have nothing to store the power in. First choice then would be more solar and fit a decent MPPT solar regulator.
You could significantly improve your engine charging by fitting the correct size cables, British built vans are notorious for fitting well undersized cables. Replace the cables to the split charge relay and battery with at least 16mm sq cables and you should a big improvement.
If you go down the B2B route have a look at the Votronic unit a bit dearer than the Sterling but a much better bit of kit.
My set up is 3 x 80a/h gel batteries, 300 watts of solar with a MPPT regulator and a Sterling B2B. I only fitted the B2B as I picked up an almost new one on eBay for £130 if I was buying one at full price I would have bought the Votronic one, the Sterling is a pig to set up.
Standard charge from the split charge in the Hymer is an intial 22 amps dropping to 10 amps as the batteries resistance rises, the B2B gives an initial 40-49 amps dropping to 20-35 amps depending on state of the battery.
That should be a C1 licence....up to 7500kg.Well if you do not have a C licence you are effectively driving without a licence. That would interest the insurance company.
Did you buy any of these Lead Carbon batteries? New technology to me too....Another battery alternative I looked at is a ‘poor mans lithium’ - Leoch lead carbon.
12v 100AH Leoch Pure AGM Lead Carbon PLH+ C100 Deep Cycle Leisure Battery NCC Class A - Alpha Batteries
12V 100Ah Ultra Deep Cycle battery for multiple applications – from Leoch’s Pure Lead Carbon series. Features • Pure Lead […]www.alpha-batteries.co.uk
