inverters (1 Viewer)
Duck Truck
1,203
1,226
UP North
Hobby 725
since 2012
Can anyone recommend an inverter to run a microwave?
I am looking towards a 3kw pure sign wave inverter.
We have 4 12v batteries onboard.
any recommendations as to a make and model would be appreciated
We would mount the inverter in the garage so a remote would be needed
Many thanks in advance for those who take the time to read and answer
Kev
Jan 19, 2014
9,395
24,784
Derbyshire
Elddis Accordo 105
since 2014
Kev
What's your budget?
The Studer AJ series are good but expensive, victron are middle of the road, and some of the Chinese ebay ones maybe OK.
I fitted a cheap Chinese PSW one that's been good but it's only 1000w. Made by Meind.
Lenny HB
53,448
150,064
On the coast in West Sussex
Hymer B678 DL
Victron are pretty good but if only for the microwave a cheaper one may do. The inverter needs to be mounted as close as possible to the batteries if you mount it in the garage you will need huge cables.
Duck Truck
Duck Truck
1,203
1,226
UP North
Hobby 725
since 2012
Hi its a 750w microwave minimum inverter would be 2kw
but would prefer 3kw as we often have Tv on whilst I am cooking
we have 4 Gel batteries all located in the garage within 2 feet of where our existing inverter is.
The existing inverter wont power up the microwave (actually lights come on dish spins but it wont fire up the magnatron)
hope that helps
I didn't fit the existing inverter
funflair
19,363
30,277
Guisborough
MORELO palace
since 2012
All sounds good to me but need big cables whatever, I used 80mm2 for a similar set up.
Lenny HB
53,448
150,064
Hymer B678 DL
A 1500 watt inverter should be more than enough, the TV will only take about 50 watts.
Microwaves can take up to twice their rated power on startup but it's usually not as bad as that, a decent inverter should handle it, the cheap ones often fall over with the high startup power required, they often don't live up to their peak rating.
Duck Truck
Duck Truck
1,203
1,226
UP North
Hobby 725
since 2012
sorry for the delay in replying our current inverter is 1500w
and doesnt drive the microwave
Dec 2, 2019
3,591
7,778
Amersham
van conversion
Since 2019
Your inverter may be 1500w but, your batteries can’t keep up with it. In order to deliver 1000w resistive load, like a heating element, inverter will draw 1100w out of batteries. That’s 91-92 amps out of batteries. Too much for your batteries. That’s what the inverter tells you. Now, the microwave is a resistive load 1:1 power factor at full load. If you try to run your microwave at half load, becomes very inefficient in power factor as low as 0,5. That means for 750w absorbed by microwave, the inverter needs to supply 1500va apparent power. To do that the batteries needs to feed the inverter with 125a. It may be less once started and stabilise in between. You are killing your batteries. A lead 100a battery can give you sustained 10a or 20a for short bursts. That’s it. You try to take more, the voltage will drop quick, until inverter disconnects on low voltage protection. To run your microwave, you need more battery power, the inverter is just a middle converter, but the source of that power remains with the batteries.
two
Aug 4, 2011
4,903
4,573
West Midlands
A-Class Fiat
I hope you ave plenty of payload?
Microwaves tend to be pretty heavy and you'll need a large battery bank.
Apr 22, 2013
911
661
Cotswolds
Bailey Approach 625
Since 2011
Our 800Watt microwave requires 1250Watts of power according to the manufacturer.
We have a 1500Watt inverter its displays says that it is producing 1280watts when the microwave is on.
The inverter/microwave combination has worked well for the past 6 years.
Dec 2, 2019
3,591
7,778
Amersham
van conversion
Since 2019
We used to have one, left it at home in the kitchen. Swooped it with a Dualit mini grill & oven. It has proper resistive elements 2x 700w, no transformers, and the choice of turning on either one, or both, use it as a grill with top one on or both as a oven. Very light. Power factor 1, same as the water heater, no energy wasted. And incredibly efficient on a multiplus 2kva.
Oct 26, 2014
1,871
3,200
Dumfries and Galloway
Pilote P696GJ
how do your batteries fair when using the microwave
Dec 2, 2019
3,591
7,778
Amersham
van conversion
Since 2019
Very nice, with that capacity and a 1,5kw inverter is a smart choice. The batteries will never need to be 100% full, and a low discharge rate will last you ages, maybe outlive the van.
Duck Truck
Duck Truck
1,203
1,226
UP North
Hobby 725
since 2012
we have 4 12v Gel batteries on board
Duck Truck
Duck Truck
1,203
1,226
UP North
Hobby 725
since 2012
We are on the verge of replacing our existing1,500w modified sign wave inverter.
We want the new inverter to be able to run our microwave.
THE EXISTING SET UP
The EXISTING set up is 4 x 12v gel leisure batteries each linked to each other by 7mm cables all located in the garage under the bed.
The inverter is 1.5metres away from the end of the battery and the cable to the inverter are 12mm all located in the garage under the bed.
The batteries are connected to the inverter via a relay which is operated via a switch from inside the habitation area,
this means we can cut the 12v supply to the inverter ensuring it is TOTALLY OFF and isn't constantly running in the background.
The Relay also switches to shore power if we plug in
THE NEW SET UP
This what we want to replace it with.
Keep the existing 4 Gel leisure batteries
Replace the inverter with an EDECOA 3,500w pure sign wave Inverter currently ÂŁ319
it comes with a remote control which we can wire into the habitation Area.
My questions are?
1) The 7mm cables linking the batteries together can they be kept or should they be replaced and if so with what gauge?
2) The cables that come with the new inverter are 16mm thick but only 600mm long NOT LONG ENOUGH to reach where the inverter has to be.
3) What size cables DO I NEED for a 1.5 metre run?
4) Can I still use the existing relay and switch to totally isolate the inverter
I think that about covers it all
Thanks to everyone who takes time to read this
Kev
Lenny HB
53,448
150,064
Hymer B678 DL
THE EXISTING SET UP
THE NEW SET UP
My questions are?
Kev
A 3,500W pure sine inverter for ÂŁ319, you areally not going to get much for that. A 3000w inverter if you want something decent is going to cost around ÂŁ1000.
If the Gels are 80 ah, a 1500 w inverter is the max if you value your batteries, or fit another 6 batteries, or fit Lithium.
The 7mm sq cables linking your batteries is far too small for normal use without an inverter, I would upgrade them to at least 35mm sq, preferably 50 mm sq and the same to the inverter.
I take it you have 2 relays one switching the mains sockets and one for the inverter. For the inverter you will need a 350 amp contactor.
Apr 22, 2013
911
661
Cotswolds
Bailey Approach 625
Since 2011
How much did they cost?
Cheers James
I’m not at home right now so I don’t have the invoice to hand, but £1700 comes to mind in 2019.
Get on to rj-lithium.com for the latest price. I didn’t pay any import duty or VAT but it was pre brexit.
Duck Truck
Duck Truck
1,203
1,226
UP North
Hobby 725
since 2012
HOW MUCH
went up the Yorkshire war cry
Just priced it
a low power 320w microwave is ÂŁ114
but its the size of a standard microwave
sadly it wont fit in the space we have
Our exisitng one is cube shaped
not oblong
sods law
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
That bit I don't understand. Microwave ovens (apart from expensive internal inverter types) achieve power variation by switching the magnetron on and off (the on to off ratio determines the power output and the intervals are quite large).
Dec 2, 2019
3,591
7,778
Amersham
van conversion
Since 2019
The microwave is not a resistive load, where the power is all absorbed. It absorbs less than the source delivers, and returns back to source as reactive power. The less it cycles on a small power setting the least efficient. A microwave will be at its best efficiency at full load setting.
I haven’t measured it, just exaggerated for explanation purposes, but I will very surprised to see a microwave to exceed 0,8 power factor.
Nanniemate
6,122
43,007
Wales
IH
I am looking to buy an ebike,I have , I leisure battery 1 van battery , I do have a solar panel would a cigarette lighter inverters work to charge the bike ,I have visions of LennyHB holding his head in his hands and crying into he's cornflakes this is the charger that comes with had bike
thanks for your advice
Jan 26, 2017
3,474
11,742
Mid Suffolk.
Autosleeper Inca
Eight Years and 28,000 Miles.
Yes, I use one..(it depends on what battery) do a forum search, there's more info to be found on the subject, and some recommendations đź‘Ť
Lenny HB
53,448
150,064
Hymer B678 DL
Still waking up with my cupper in bed at the moment.
Won't be able to do that with a cigar lighter type charger.
You are going to need a 300 watt inverter preferably 500 watt as switch mode power supplies often take a high current at switch on if they have not been used for a while.
Unless you are going to fit a 2nd battery it would be best to restrict your charging to when driving.
