Toaster and iron, forget it, you will murder your batteries in no time! Hair dryer should be OK, you'll want a fairly decent size, so 1800kva or higher.Hi all, can anyone help please? I need to get a new inverter and am not sure what power I need to run small appliances, ie toaster, iron, hairdryer, small vacuum. (Not all at same time!) can anyone advise best place to get one and what size I would need. Any help will be greatly appreciated.
If you don't have a large battery bank, little point in shelling out on a large wattage inverter. The old adage applies 'you only get out what you put in'.
Was That Static, or with the Engine Running?. 108A@12.2V makes a power drain of 1317.6W. which would include all the little "Phantom" drains Either very efficient, or the Meter is in error?. BTW, I am assuming the 140OW (5.7A @ 245V) is MAX RATED power and not the actual power drain of course, as most items actually work below rated.View attachment 147150 For further info, this is our battery monitor when running the coffee machine (1400w) to make a cappuccino whilst using the inverter.
No, that was towards the end of the heating cycle, it goes up to around 168a initially, but then drops back when the element shuts down. There was also sun on the panel, so a little bit of solar assistance has to be taken into the mix!Was That Static, or with the Engine Running?. 108A@12.2V makes a power drain of 1317.6W. which would include all the little "Phantom" drains Either very efficient, or the Meter is in error?. BTW, I am assuming the 140OW (5.7A @ 245V) is MAX RATED power and not the actual power drain of course, as most items actually work below rated.
