Inverter (3 Viewers)
ShiftZZ
21,383
84,583
Dark Side of the Moon
Bought one or two cheap ones, never had any luck.
Any suggestions as to makes and model to buy?
Use, laptops and hair straightners,
jollyrodger
6,282
26,419
Devon/Cornwall
'Obby
Since 1968'ish
Don Quixote
2,966
5,258
Lost in La Mancha, Spain
VW T6 Campervan
Look at this one sells well and works a treat. Good luck using straightners on your head..........
Sep 3, 2012
7,556
26,081
Cheshire
C Class Elddis 175
8+ years
Hi John
can you advise what you run with this inverter please.
Jim
Jun 22, 2012
231
130
Ebbw Vale Gwent
Rapido 9048df A class
seven
Unless you a willing to splash out for a good one there is no point, cheap ones are what they are.
I have a pure shine inverter 3000 watt which will give me 2000 concistant watts battery's permitting of course, we use microwave, toaster, hair dryer for the wife washing machine, TV, laptops, charging and I run the fridge during the day time as long as the sun is shining.
To support this I have three leisure battery's and two one hundred watt solar panels.
Don't be fooled by cheap imertations or modified version as you have already found they are just not up to the job.
Don Quixote
2,966
5,258
VW T6 Campervan
Hi John
Jim
Jim, as I only have a 800watts inverter ( that's all I need ) I cannot recommended what you do or do not run on an inverter. A 2000 watts version is more than enough for 90% of the things you might want to run in a MH.
As @Hydrocell states "cheap ones are what they are" but none the less they work. If your going to use an inverter every day for 7/10 hours then of course buy the "top of the range", but if your only going to use a hairdryer for 15 minutes cheap is good enough.
Sep 3, 2012
7,556
26,081
Cheshire
C Class Elddis 175
8+ years
thats all i want it for -a SWMBO hairdryer -not mine for a few mins plus possibly a microwave with a mechanical clock for a few mins-just curious what you used the one you noted for-wasn't asking for recommendations-just looking for a reasonably cheap one that will work with hairdryer (500w) and microwave (700w)
Don Quixote
2,966
5,258
VW T6 Campervan
Jim, the one I have shown link to will do the job just fine. Microwaves are funny beasts as it might say 700watts, but on start up could be as high as 2000 watts, so be careful. Also be aware using a microwave for long periods will KILL your batteries.
kelv
672
895
leicester
Carthago 145
I purchased a sterling 600w pur sin wave inverter from roadpro £180 works straightners fine
Chris
21,056
278,943
10 years
Dunno if gas hair straighteners exit, gas curling tongues certainly do.
Same thing?
Not an issue for me, my hair's thinning.
WTF, who wants fat hair?
My hair is " thinning" too John.
In my case that sounds much better than " I am almost bald":D
Jun 22, 2012
3,761
40,903
Sherborne Dorset
You can get gas tongs, brushes and straighteners from tesco boots etc which work ok. Need a new one so am waiting to see if the babyliss one is in the tescos double up on monday.
