Inverter for electric bike (4 Viewers)
Ridgeway
3,666
6,176
Lausanne
NiBi Arto 85E
So until now we've managed without an inverter as all the devices we need can be run off 12v (ipad, phones etc) Now though we may need to charge an e-bike and i can only see an inverter being the solution.
I was thinking a 300w true sinewave device of a good brand like Sterling as the e-bike's battery charger is 42v at 2.0 amps so this would be plenty, right ? I assume that cheaper devices will chew through more leccy to give me the required output.
Any thoughts ?
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
I have a 350 watt sterling pure sine £100 if you want at a meet?
THUS but with bigger cables and inline fuse
11,956
16,570
A 150W would be more than adequate. You don't need a pure sine wave.
bilimanjaro
57
22
grimsby
autusleeper
ten years
not trying to hijack thread,,but,,would a bog standard 150watt inverter charge a ebike battery @24v/10.5 amp... of the leisure batteries [110amp] whilst engine running..
thanks in advance...
Techno
Jul 28, 2010
15,475
20,756
May 2010
Not yet I don't? I'll bring it to Chester and Peterborough for first refusal :thumb:
Any thoughts ?
Just what I use.
The only problem being that our pair of ebikes if fully discharged take a significant lump out of our single 110Ah. We have 100W solar. We just about cope as long as good sunshine.
But we don't drain them both every day.
Pure sinewave is a good guarantee that you can plug anything into it. My ASUS tablet does not have a 12V solution for a proper charge because it needs 15V off the mains charger.
Aug 10, 2012
842
908
cambridge
Globecar
since2001
techno
just sent you another mail but it goes missing and dosnt appear in my sent box
i am guessing you didn't get this PM either:Sad:
neill
32,673
66,647
We were advised to get a pure sine wave inverter for our electric bikes by someone in the trade who we trust .... is this any good?
Ridgeway
Ridgeway
3,666
6,176
Lausanne
NiBi Arto 85E
Just what I use.
Thanks for the feedback on that and I wondered how much they would take out of the battery, hum I feel the need for some solar:roflmto:
Ridgeway
Ridgeway
3,666
6,176
Lausanne
NiBi Arto 85E
Gone for a 300w Sterling unit, will test it next week:winky:
Techno
Jul 28, 2010
15,475
20,756
May 2010
techno
neill
In case anyone is wondering?
The original pm never arrived but the others mentioned here were all received and replied to. Neill has bought the 350 watt pure sine Sterling subject to inspection etc.
A true bargain :thumb:
JockandRita
11,468
150,295
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
Sticking with the OP's post on an inverter for charging bike batteries, does it have to be a pure sine wave inverter, or will a modified sine wave inverter do the job, without damaging the Li-ion batteries?
Cheers,
Jock.
32,673
66,647
Any comments on the above for doing this????
Ridgeway
Ridgeway
3,666
6,176
Lausanne
NiBi Arto 85E
Sounds like it's not really required.
Am I correct in assuming that as the batteries are being charged by a transformer then the input quality is less sensitive ?
Mastercamper
578
1,955
Northumberland Flag Flier
50 years campervanning
I believe that to be the case.
I Charge my wife`s mob scooter from an inverter running the scooter battery charger, when the campervan engine is running.
Berniesbargreece
14
Middlesbrough
Autohome Wildfire
ok guys: I know nothing about electricity so please bear that in mind. Here's my question: your help is appreciated.
I have a 150W solar panel on my motorhome roof, this charges my leisure battery. The motorhome is based in Greece so there is no shortage of sun.
My main concern is my ebike. I have one bike only, 36v 16AH battery and I will charge is when needed. I want to buy an inverter that will 100% be compatible with this use. I don't want to be dependent on any campsites or any people for plug ins. I have just bought a 300w inverter but reading some of the comments I am starting to think it may not be good enough to charge the bike. Could anyone recommend an inverter that should cope with most things.
I also have a drone that will be key to my work filming in Greece. The batteries are powerextra batteries. 15.2v 4480mAH LiPo batteries.
inkey2019
24
7
Faversham
Burstner 747 active
since 2003
Look at Victron inverters they do both types. Have never had a problem with mine. They also do solar charger regulators mppt. Also very good.
JockandRita
11,468
150,295
Lincs/Cambs border
N+B Flair 8000i
Berniesbargreece. We charge up our 36v E-Bike lithium batteries off our 300w modified sine wave inverter, without any problems. (y)
The supplied charger has a maximium output of 2A. I checked with the bike supplier first, before charging via the inverter, if the two were compatible.
Cheers,
Jock. :)
