- Oct 27, 2013
- 712
- 11,115
- Elddis Magnum185GT
- Since July 2012
Every now and again, I get a fault on the water pump whereby the pump seems to splutter or surge and pressure at hot or cold taps drops. When it does this, if any lights are on, they flicker in time with the spluttering. Shutting the tap off then back on again doesn't cure the problem; the only way I have found to stop it is to shut the water pump off at the control panel and then back on again after about 10 seconds. Then everything seems to operate normally.
Pump is Shurflo 4029-181-A32. 20 psi, 7.5 lpm.
Van is Autotrail Apache 2013, so pump (original) is 4 years old.
Does anyone have any ideas how to cure this please, or is a new pump on the cards?
Thanks, Chris
Thanks, Chris
