Tim Raphael
Hello
I am trying to help my cousin with that worst of faults, an intermittent electrical failure while driving !! I will try to explain the fault and would be grateful for any ideas or experiences of a similar fault anyone has had.
The vehicle is Dec 2000 Fiat Ducato based Adria Twin running a 2.8 TDI, LHD (France). I have seen the vehicle and there are no obvious signs of any modification from the original.
The fault is an electrical failure whilst driving which effectively kills the engine. However, you are left with, once the ignition is switched on just the two red lights, Oil and Battery still showing but no other lights at all. With these two lights on you can operate the starter motor which turns over strongly but the vehicle will not start and the other lights do not appear. It also seems that cab electrics are disabled, ie windows etc. The habitation system seems to be working as should and shows both batteries fully charged.
Then, a higher being takes over! .... and sometime later the other lights reappear and she starts!!
So, are we looking at a possible ignition switch problem, the safety override switch, a solenoid, Alternator ............... ??
Any comments will be gratefully received as we all know that a fault like this is just a nightmare.
Thank you in a
Thank you in a
