Intermitent engine cut out
TREES MOVING
HORNCHURCH, ESSEX
COACH BUILT
2 YEARS
Hi, I hope someone can help. I have a Roller Team T590 purchased new last year based on a Fiat Dicato 2.3 litre Euro 6 engine (manual). Ever since new the engine will cut out, intermitently, so that there is no acceleration. The engine goes into idle mode (800 revs/m). If I put my foot on the accelerator pedal, the revs do not rise. This idle mode can last anything from 10 seconds to a minute, after which the power returns. I returned the van to a main dealership in East London where on the second visit they said they had cured the fault telling me it was a faulty hill start switch. The problem remained and I now have taken the van to a Fiat dealership in Kent where they cannot identify the fault. The engine went into idle mode about 7 times on a short 15 mile joirney a couple of weeks back. As stated above, the fault is intermitent but seems to occur mostly when breaking or de-accelerating especially on hills. If anyone can shed some light on this it would be greatly appretiated.
John (TREES MOVING)
At first guess....
Intermittent Throttle pedal position sensor or associated wiring fault.
But it should throw a fault code in the OBD memory.
Buy yourself an OBD2 reader & keep it plugged in whilst you drive, it'll give you the fault code when the intermittent fault occurs. The type that I think might suit you best is the permanent plug in one that uses your smart phone.
It is odd that the vehicle isn't storing the fault code
Something like this below.
dont know about the 2.3 engine but had a similar problem with my 2.2 relay, started with hesitation on accelerating and eventually cutting out but would always restart, gradualy got worse and had egr valve changed as had a code for it but still had problem which turned out to be the fuel pressure relief valve, my mechanic was running it and checking various perameters and noticed fuel pressure was fluctuating when just ticking over so new valve and all good once again
Thank you for your replies. I have found out what causing the engine to go into idle mode. If you put your foot on both the accelerator and brake pedals, the engine goes into idle mode for about 10 seconds if no pedals are touched. This happens with the faintest of touched. This is meant to happen and that is why a fault was not showing up. This in my opinion is potentially very dangerous and I need to know why FIAT thought that this was a good idea. I wanted this to be disengaged but the Dealer said this was impossible. I would welcome your comments.
Never heard of that before but I agree it could be potentially dangerous although left foot braking isn't something you would normally need to do in a van unless it was a full auto.
This is quite normal on modern vehicles
I'm trying to understand the circumstances under which you would have a foot or feet on both pedals at once? Other than an expert user with an autobox doing it of course.
Most vehicles built since about 2000 (fly by wire/canbus) do the same, likewise with the handbrake, it's a fail-safe in case your accelerator gets stuck or goes faulty.
I'm trying to understand the circumstances under wbich you would have a foot or feet on both pedals at once? Other than an expert user with an autobox doing it of course.
Easily done when wearing work boots on size 12 feet.
Must admit can't understand why you would want to do it with a manual. I used to left foot brake in Automatic cars, but in the Ducato (Comformatic box) the peddle is so far over it's not practicle.
Perhaps the OP is a race/rally driver from turbo lag days:p
which normally means it needs the brake light switch adjusted or replaced. Had it happen on my last car
If that's the case why did two separate main dealers not mention this.
Can't say I've notice on my 2015 Hyundai as my left foot braking days are a long distant memory of my youth.
Coz they know naff all about it probably? What’s new.
Found this out when bedding new brakes in for mot- kept foot on throttle and gently braking- engine cut out, Kia Sedona 3.0cdti 2006
You might want to dry the brakes out after going through a flood.
Although probably more relevant to drum brakes rather than the more common disc brakes on modern vehicles.
So has this explanation sorted out the OP's problem? From the way he was describing it there was an awful lot of left foot braking or is it still a matter of sensor switch adjustment?
Change of footwear might help :D.
