- Oct 5, 2021
- 385
- 659
- Rapido C86
Hi again everyone. Following on from some great responses to another question I have decided to install Gaslow with an external filling point mounted on the skirt.
The main challenge is getting the hose to under the van. I would like to avoid drilling through the floor given how well sealed and thick it appears. It would be preferable to go through the drop vent.
The problem there is that it is directly under where the cylinder stands. After getting to vent there is an easy route to the skirt through the vent and out.
There is plenty of headroom above. So options seem to be
1. Steel hose through one of the gaps at the bottom of the cylinder. This seems like a bad plan because of risk that cylinder moves and disrupts the hose.
2. Build a small wooden platform to effectively raise the floor and to raise the cylinder. This would allow me to cut a hole in that to thread hose through and down into the vent.
3. Drill directly through the floor
I haven't bought a cylinder or kit yet as I peruse the options. I am hoping that a single 1.5m hose would run from cylinder to the fill point but I need to properly measure. I also wonder whether there would be sufficient room to avoid any undue bending of the hose.
Any thoughts based on your knowledge and experience?
Many thanks
Many thanks
