Inflatable Air Awnings (1 Viewer)
Sep 25, 2012
516
1,217
West Cornwall
13 Years, 20 years with a caravan
Hi all. I'm looking to purchase an inflatable Air awning. I've got an Fiamma F45s canopy and the height is 260cm to the ground. Any advice as to which would be best. My canopy is just over 4mtrs wide.
Many Thanks
Phil.
Jan 11, 2010
2,688
8,817
Chester
Auto-trail
Well that`s our 13th year & still loving it.
We sold our inflatable awning went back to a metal tube one, the reason being unless you are on level ground the inflatable just can't cope, you can't adjust the legs so the awning doesn't sit right causing the outer legs to buckle.
On level ground they are fantastic but how often do you get a perfect level pitch.
Boycie
Sep 25, 2012
516
1,217
West Cornwall
Thanks for your reply. We will be on a level pitch for some time so hopefully it would work.
Phil.
JnJ
Mar 15, 2019
137
757
South Ayrshire
BENIMAR mileo 286
2018 had 25+ years tent/caravan touring
We have an Outdoor Revolution Sportlite Air 320L. It fits height 250-265cm. It's a great awning, not too heavy but quite robust. I have made an extended strip for each internal end so it can be attached to the side of the MH with Limpet type suckers to stop any draught.
TCG
Jul 6, 2017
1,335
1,997
Salford Priors
Autotrail Delaware
Not quite correct, the new kampa domectic awning that we purchased last summer, has a zip on each side, that you can open if you want to extend the fabric of that particular side
Boycie
Sep 25, 2012
516
1,217
West Cornwall
Many thanks. Will check out.
Reactions: JnJ
3,209
8,729
PVC
1995-2004 & 2017》
Sitting on a THS this year we heard one horrendous "explosion" and then sat and watched an awning very slowly but gracefully deflate as occupants tried to find the way out..
Sure not for them but rather amusing to rest of field.👍👍👍
5,019
49,372
hull
Laika Ecovip 300
Have been using a vango Kela tall 2 for some years, then grandkids sleep in it when we are away, haven't had a problem with stability. We have been using it for outdoor space for us when staying for a few days, or more, at one place. This year i treated myself to a quest pro I can just put it up on my own and take it down again but would be easier if i were a few inches taller 😂
4,682
48,348
Bury St Edmunds, West Suffolk
Weinsberg Cara
since 2007
Had this happen to us as the bladders expanded in hot weather and exploded. Nearly died of shock.
A quest pop up for us now.
Phil
2,688
8,817
Chester
Auto-trail
Not seen one of those, is that just the fabric you can extend? what about the inflatable Tube?
Unless you can make the legs shorter or longer you will have the problem of the frame still not sitting correct.
3,209
8,729
PVC
1995-2004 & 2017》
Phil
Yes indeed it was a gloriously hot day in July..
However I assumed they would be fitted with some sort of pressure release valves to stop this happening..
409
859
Dethleffs Advantage
Since 2008
We use the Motor Ace as per the pic. Think its quoted weight is 35Kg, comes in a large holdall complete with pegs, poles, pump. The fiddly bit is threading the beading through a long awning beam but otherwise takes 5 mins to inflate and another 5 to peg out. Need to check the central inflatable beams do not intrude on the habitation door. I seem to recall it comes in three heights. We like it, all the panels zip out if you wish or zip the top half down to use as a window (useful to keep dog from wandering off!) Has curtains if needed, large floor space, bit like taking your conservatory with you
Broken Link Removed
This attached to a 4.5m Omnistor.
If you do not over-inflate the tubes they cope with the change in temperature quite well, we have pitched on various terrain and the beams are flexible enough to compensate for uneven ground and strong winds, within reason!
3,209
8,729
PVC
1995-2004 & 2017》
Broken Link Removed
What a terrific colour match,👍👍👍👍
Reactions: f6c
TCG
Jul 6, 2017
1,335
1,997
Salford Priors
Autotrail Delaware
Hi Rob or chris
Yes the zip is on each side where the roof air beam joins the leg air beam. unzip and it allows the leg to drop while increasing the amount of fabric between both air beams
683
18,437
Plymouth
Adria Compact
Since 2013
Boycie we have an inflatable driveway awning, we used it a couple of times with our Burstner, but was not really ideal because of the roof line, we didn't have an awning rail and had to throw the straps over the top, our daughter used it for the grandkids to sleep in but they are now of an age when they have other things to do so it is surplus to requirements. It is a Vango (I think it is a Kela) but if you might be interested in it send me a PM, we are not too far from you, just over the border in Plymouth.
Boycie
Sep 25, 2012
516
1,217
West Cornwall
Thanks Sue.
I've managed to source a kampa air Grande which I'm picking up tomorrow.
Boycie
Sep 25, 2012
516
1,217
West Cornwall
Thanks everyone for your advice and suggestions. I managed to source a kampa Grande 390xl for a very good price from Camping Leisure Canvey Island.
Phil.
  • Nice One!
Reactions: f6c
2,175
4,428
Carado T339
5 years
Phil.
We have one of them. It's a big beast and I found it difficult to put up and get down at first. I am fine with it now. Just have to get tw zip out panel in tje right openings.
Never had a problem with slopes. We have the driveway break out awning rails which are alot better than the throw over straps.
Boycie
Sep 25, 2012
516
1,217
West Cornwall
At the moment I've got a 4.5mtr safari room but I'll be taking it down on Thursday and changing over to the air awning. I'm sure after a couple of times it should be a lot easier. It slots into the front of my f45s awning rail no throw over straps. I'll let you all know how I gelt on.
Phil
Boycie
Sep 25, 2012
516
1,217
West Cornwall
Hi All,
Just an update with regard to the Air Awning. Currently full timing in the Van until we can find a place to rent in or around the New Forest. Anyway I digress. The Awning was tested to winds of 22mph according to Dometic. We are currently experiencing gusts of 52mph winds and the Awning is coping extremely well. I am very pleased with it. If we had the safari room up at best it would have been crashing and banging at worst it would have collapsed.
Phil.
