immobiliser prob will not start
craildog
peugeot boxer
2004 boxer
engine ecu permanent fault coded auto start time elapsed
bsi permanent fault transponder not stored
can any one help
2004 boxer
can any one help
Has the van had a low battery condition when trying to start it ?
Also check there is a good earth bond between chassis and engine.
thank you for your reply yes battery was low when starting attempt i then fully charged battery thats when the problem started and van will not start.
Proly corrupted the ecu ... sorry ;)
Do you know anyone with a proper scan tool ( not one of the cheaper ones, but one of the pucka £1000'ish ones ) ?
Might be able to sort it... but the good(ish) news is that pre-owned ECU's are pretty cheap, though you will proly need that scan tool to reset a replacement if you are not extremely lucky
