I think someone is twisting our melons......I think it has been put together wrong as the bar that goes into handle works it’s way out when operated it just don’t look right to me the angle of the rods don’t flow right any advice lads Andy
I had same on my rapido. Where the wire goes into door.There is most likely a break in the wire. Pull back the loom cover carefully and you will see the wires.Thet are very brittle. I rejoined mine.27 TUG
How do you remove the door casing. I have a problem on our Rapido where I can hear the central locking working but it will only open with the key so need to get in and have a look.
I have read on hear about similar issues and cleaning the contacts but no contacts visible just a wiring loom at the bottom left corner.
