I should have thought faster!
Gellyneck
Scotland
More than toes wet now!
I've been thinking about fitting reversing sensors on our 2013 Autotrail motorhome.
Been having a look around on here for advice \ recommendations on what to go for and on tinterweb for availability and pricing.
Having decided to cancel our forthcoming jaunt to D&G as a result of CV I thought I'd better take the motorhome out of storage for a wee spin to ensure batteries were fully charged having just had to get the airbag ECU reset.:crying:
So, off we go out along the motorway for half an hour or so and same back to storage.
Reversing back into our storage pitch, and given it was earlyish morning with the sun at a low angle (yeh, I know - sun, never in Scotland!) dazzled in the mirrors and reversing camera.
And, you've guessed it! :crying: :swear2:
As you can see, I've got the bit that's broken out as well.
Question for the gang is, is it repairable :pray: or is it a new panel?
After trawling about on here for previous posts I was kinda thinking maybe seeing if I could get some ABS pieces (it is ABS or similar and not fibreglass) and MEK and sticking these to the back of the panel over the cracks (full access is available in situ behind the panel). And, maybe, some wet and dry paper to ease off any irregularities left on the face.
What's the thoughts?
The way I repaired my plastic fairings after a off with the bike:
Glue the bits together. Sand at the back and add a metal mesh ina fibreglass mix to reinforce it. Fill the missing voids with melted abs. Sand down and spray fill with plasticote few times. Then spray the colour.
I did exactly the same damage on my 2012 Autotrail but I managed to do it on the day I collected it brand new from the dealers.
Autotrail only charged around £90 for the new panel if I remember correctly. (y)
Heck, with the price of replacement bits for a bit of injection moulded plastic, I forsook beauty and elegance and stuck the pieces in with clear "duct tape" and stopped worrying about it. I've now had three "dings" at the rear and the level of duct tape has grown, even to the point of having to tape in a rear light as the mount had broken. Oh yes it did pass its MOT this year. Duct tape 1; MOT 0! Yeeah!!! Beauty contest = 0!!
That clear stuff is great. So far I've used it to repair a tear in my puffer jacket ,another's in a waterproof. The latest was to tape my wing mirror back on
"Araldite " the broken bit`s back on..... Clean the back and build up with Fibre glass Matting..
Then body fill the outside.... rub down and prime and a few coats of white with a rattle can..
Looks an easy job... (y)
I would do the above and use Gelcoat as the filler. Take your time sanding it smooth to match the existing shape. And you also can buff gelcoaf so no paint!
It may be possible to stick the broken bit back with "Super Glue"...
But not all plastics stick with super glue...
I have found a lot don`t.. :shake: :shake:
And get them "Sensors" fitted quickly... :giggler:
I had thought about using glass matting and resin but was concerned about it sticking \ bound strength onto ABS. Does this method work?:unsure:
That was going to be the final step.(y)
Not a fan of superglue so discarded that option.
As for the sensors, I blame the wife as she usually walks behind when I'm reversing waving a huge red flag and shouting at the top of her voice "watch oot he's a novice at this caper"!
:RollEyes:
As long as you clean the back up from road grime and dust... and rough up with course sand paper..
It will stick... (y)
Read the book, seen the movie and got the tee shirt, I swear the big flower pot moved as I was reversing.
I managed to repair mine with a product called Plastex HERE I was fortunate as the repair was behind an overlap with the centre section so you couldn't see it once done. So may not be suitable for your purposes but all options are helpful.
Thanks Dane. I had seen your previous feedback on other threads and it's an option in the pot (eeeeek no, not flowerpot!) ! Much appreciated. (y)
I’ve got the T shirt as well I’m afraid :notworthy:
I now get SWMBO to watch me back on every reverse, no matter how trivial it appears.
I do get some strange glances from the “best reverser in the world” types, but I haven’t reversed into anything since. (Touching wood here)
as for the repair, as others have said, it looks a straight forward job as you have all the pieces. (y)
After 30 odd years in the Fire Brigade, i can say that 90% of FB accidents were due to reversing and not being 'watched back'. We used to insist that no vehicles were reversed without being watched back, but try enforcing it
' i was watching the driver reverse, but i stumbled and fell just at the time the appliance hit the wall' et al
having someone watch you back, who actually cares if you hit something, is by far the safest method !!
I'll go with MikeD on that. I did exactly the same in France a few years ago to our Autotrail when a concrete bollard came out of nowhere and attacked me. Same damage same place. Dealer fitted new panel, about £95 from memory. Just had to wait for workshop time.
Looks an easy repair. I’ve saw Alan repair his and it was much worse than that. Go on give it a go. Good luck
Have you thought of 'fablon' (sticky back plastic) I needed to hide a similar gash in the rear of a vehicle so headed to B&Q white Is easy to get and in minutes hide the issues cut in carefully on returning to the yard 21 days later the boss looked at the small scuff on the bottom of the vehicle saying 'that's no so bad' it hid the huge football size hole so well he didn't notice it. I still have the remainder of the roll also have black Just in case) Only needed it once.(curvery corner of vehicle, tree branch, lousy banksman marshal) the carpark repair stayed on for 9 months washed every day
I started writing this as MasterB posted
Yeh, looks an easy repair when you're watching Alan! Aye right.;)
However, and here's a great plan, when your up in court fighting your case Alan will be at a loose end so he can wander over and I can also watch him making it look easy. Obviously just to confirm you're no tellin porkies!:giggle:
Weather permitting will be giving it a go in the next week or two.
Luck! More like :pray::pray::pray:
You could try a hot melt glue gun on it. I believe the high temperature guns (195c) might do the job and weld the pieces together. Might be worth practicing on some similar material first though.
Was thinking about shaping ABS pieces (if that's the way I go) with a heat gun and then glueing these to the back of the panel.
That would work as a reinforcement but I reckon if you line up the pieces carefully and tape in place, then you could hot melt the cracks from behind. There would then be less finishing to do on the face side and it could still be reinforced from the back afterwards.
If you self repair don’t forget to drill a small hole at the end of each crack/split to stop it spreading any further.
I had seen that on the other threads I was looking at but, a question, will I need to if I'm plating over and beyond the ends of the cracks? Trying to minimise the "damage" to the face of the panel.
I've used this product to repair similar self inflicted damage on an Autotrail. Works really well and sands down to give a good smooth finish.
https://www.amazon.co.uk › Solarez...
Solarez Epoxy Pro Repair Kit: Amazon.co.uk: Sports & Outdoors
Take the broken bit to your nearest motor factors who mix car paint and get then to match and make up a spray can. The paint will be one of the Fiat white colours, to cut down on searching. Spray and finish off with a few coats of clear topcoat.
