I need to increase my Water Discharge Flow (1 Viewer)
Apr 17, 2016
508
568
Peterborough, Cambridgeshire
Carthago Chic E Line
Since March 2004
Attention grabbed! Does anyone know how I can increase the pressure of the water to flush my Thetford loo?
It does not have a separate pump or flush water tank but appears to have a solenoid? that allows water to flow when the flush switch is operated. Definitely a Thetford.C260 cassette and porcelain bowl.
Dec 6, 2011
11,596
25,450
South Wales
Coach built Adria
Ours has similar set up and no issues with the pressure.
Do you have a block or scaling in the pipeline
Lazyboy
Apr 17, 2016
508
568
Since March 2004
No scaling as it is fairly new. I suppose a blockage may be possible. Could that happen on a new setup?
Lazyboy
Apr 17, 2016
508
568
Since March 2004
If i take the pipes off either side of what I believe is the solenoid what would be the consequences. I guess that the pipe shall we say "bowl side" will just let water drain back that is already in the pipe. Does the pipe leading to the solenoid have water pressure in it? Meaning turn the pump off, remove pipe and then switch pump on again to flush through any debris. Would the system have to be primed after that?
Dec 6, 2011
11,596
25,450
South Wales
Coach built Adria
No need to prime the system and I would check that nothing is blocking the solenoid.
17,635
43,358
turn the pump off and there is no pressure if you open a tap briefly. Take the pipe off, point it in a bucket and have an assistant turn the pump on for a few seconds. It will clear the pipe and show the pressure. Trace back to the pump or forward to find the restriction
53,476
150,202
What type of water pump do you have & is the pressure good at the taps?
Last year I replaced my submersible pump with a Shureflo, there was a noticeable difference in the loo flush, a pain in the butt as it uses more water well that's my view.
