- Sep 29, 2019
- 3,058
- 7,070
- Hymer Exsis
- 20 years
Well, the floor in my Hymer Exsis I does.
The floor is raised in the high wear area by the kitchen about 40cm round. It was much worse in warm weather and disappeared when cooler. It is now there all the time leading to a springy thud every time you walk across it.
Having repaired a delaminated floor in caravans before, this isn’t the same construction. It feels only as if the very top layer of ply or thick Lino has delaminated.
I need to repair it as it’s driving me nuts!
I can see my options are to drill a hole in the middle and then use that hole to squirt lots of glue in, then weights on the floor and let it dry and fill the hole in later.
Other option is to cut down the plank effect between two planks and create a slit then do the same which might be less noticeable than a hole.
My musings are which glue to use? An expanding polyurethane might not be the best option for obvious reasons. I was thinking of a two part resin which will be nice and runny but harden over the course of a few hours.
Has anyone sorted this? Any tips?
