You won' get the lad out wants to be a boy racer again ha haYay! Look forward to seeing it! ( Robs test driving a MX5 on Monday !! Eek will we get iadout of it?!!)
7.2m I take it is the old model, hope you got a good deal.Thanks for all your views guys didn't buy the i598 as the island bed was very cramped against both the toilet and shower as mentioned by @bellabee but we have bought a 2017 unregistered i678 single beds at back, drop down at front , large garage 7.2m long
Gary and Janet
Yes got a good deal just reading threads about batteries now as need second leisure battery and solar7.2m I take it is the old model, hope you got a good deal.
Ditch the AGM and fit a couple of Gels. That's what I did on my DL after the problems I had with the AGM's on my Exsis.Yes got a good deal just reading threads about batteries now as need second leisure battery and solar
3500 updated to 3850 which gel s do you recommend and which solar controllerDitch the AGM and fit a couple of Gels. That's what I did on my DL after the problems I had with the AGM's on my Exsis.
What chassis is it 3500 or 4250kg?
Living on borrowed time, the Banners were a disaster the Varta's fair a bit better. Would be interesting to see what the capacity is on a controlled test. The ones I had were down to 10a/h at 18 months old.We have still got the running bull AGMs that we started with had no problems with them at all in two and half years.
As 2 new Gels will not cost an awful lot more than one AGM and the Gels will give a life of 5 - 10 years, with all the problems with AGM's (just look at the German forums) it's a no brainer far better to change to Gels. You don't throw it away you ask the dealer to swap it, if he wants the sale he will do it.We added a 2nd Varta AGM battery as it seemed pointless chucking a brand new one away to switch to Gels.
The Exsis we had, we uprated to 3850 but were still on the limit on the rear axle. You can increase the axle loading to 2240kg (from 2000) by fitting air suspenion and changing the tyres, 16" wheels won't need a tyre change.3500 updated to 3850 which gel s do you recommend and which solar controller
Gary
I had 2 fairly new Gels in my Exsis so I got the dealer to swap them over then added a third, nice to have decent battery power could do with more but don't want to waste garage space.@Lenny HB. Yep if you have the option to swap that sounds a good idea. We didn’t really look into the 2nd battery option until we’d got the van home so wouldn’t work for us.
Thanks Lenny lots to think about before I make my decision defo going 2 batteries and at least 200 watt of solar thanks for input really appreciatedThe Exsis we had, we uprated to 3850 but were still on the limit on the rear axle. You can increase the axle loading to 2240kg (from 2000) by fitting air suspenion and changing the tyres, 16" wheels won't need a tyre change.
I have 3 x Sonnenschein SL75 Gels in my van, they are 78 a/h at the C20 rate, they are the same battery as the Exide G80/ES900, Sonnenschein make the Exide Gels.
Another Varta AGM would be around £185, the SL75 is £142, Tanya normally give a 5 or 10% discount for sighing up to their newsletter if not phone then and haggle.
Two of the SL75's will give you higher capacity as you can take the Gels down to 20% DOD and they will still give you a long life. If you go the AGM route it's pot luck it they last more than 2 years.
If you decide to go the Gel route get the dealer to swap the exsisting battery as part of the deal.
Probably the 3 best solar regulators are either the Victron MPPT, the Votronic MPP or the Schaudt LRM1218. The Victron & Votronic are avalible in different sizes the Schaudt is 275W. If you are going to fit 300 watts or more of solar I would go for the Votronic as it has an output for AES fridges which will switch the fridge over to 12v when there is excess solar avalible.
We have the EBL29. I suspect the main difference is the batteries it supports. Ours does lead acid and gels, yours does gels and AGMs.Our van is a 2017 model, too. We have the EBL30
EBL29We have the EBL29. I suspect the main difference is the batteries it supports. Ours does lead acid and gels, yours does gels and AGMs.
