Hymer elektroblock problems (2 Viewers)
PaulaT
5
York
Hymer S820
Can anyone help? I blew a 10amp fuse on the circuit for the lights, extractor fan on my S820, I,ve replaced the fuse but now nothing is working on the 12v all I have is the sockets through 230v can anyone help, I've tried unplugging for a while and I've taken out the big 50amp fuse next to the leisure battery and put it back in but the elektroblock is not resetting itself. At my wits end!! Paula
PaulaT
PaulaT
5
York
Hymer S820
Yes it's a rocker switch to either make or break the 12v, I've tried it but nothing happens.
Rob e Lee
452
575
Surrey
Since 2011
Its worth trying bridging connections on rocker switch - could have burnt out when fuse blew.
Rob
PaulaT
PaulaT
5
York
Hymer S820
If the elektroblock has shut down what then? This has happened before but reset itself after a while but is not doing now
Oct 5, 2009
348
315
anglesey
Autotrail Delaware
If you google A & A Caravans lots of advice on their web site used to be in Conwy North Wales but have recently moved premises.
The owner Alan is very active on the Out and About web site which is free to join.
Feb 24, 2013
13,090
101,511
Bolsover, Derbyshire
Hymer S800
not long enough
we have an 800S 2008 vintage and occasionally get a similar issue
I do very much as you have but also switch of the elektroblok, then remove 50A fuse, give it a count of 10, put fuse back, switch on EB so far it has worked for me about 4 times
there may be a limit to this fix though and you might have reached it o_O
PaulaT
PaulaT
5
York
Hymer S820
Thanks, just tried that and still nothing I'll have to maybe get it to an expert, trouble is I am staying in it at the moment!
mid4did
526
728
N.somerset
Hymer Tramp R 655 GT
started in a minivan 1970's when I could fit into it.
Have you switched on the 12v circuit on the DT200 panel?
PaulaT
PaulaT
5
York
Hymer S820
I haven't switched anything off so assume the 12v switch is still on the DT200 penel (where will I find this please?)
Pulling the fuses will turn off an electroblok. You must press the 12V switch to turn it on again.
GWAYGWAY
4,213
3,306
Dover
Hymer ML I 580
4 years
Above the door, the big control panel , is it ON with all the fuses in, and did you find WHAT blew the fuse, a faulty unit somewhere you need to turn off everything and start again one at a time to find the circuit that is faulty..
eddyt
newcastle on tyne
hymer b544 a class
since 2014
hi
it might have a glass fuse inside the electroblok unit.
