It's Fiat engines, 2.8JTD. However seems bizarre to me for it to have the high payload it does ie: 4,500kg & 5,500kg Gross Train (giving a permissible 1000kg trailer Weight), 2 rear axles and have it all being dragged from the front?That would be a no. Can't see how you could have rear wheel drive and a tag axle. Presumably you are on a Fiat, Peugeot or Citroen base vehicle.
Geoff
Check out a lot of lorries, tag axle AND rear wheel drive, drive is generally on the front axle of the twoThat would be a no. Can't see how you could have rear wheel drive and a tag axle. Presumably you are on a Fiat, Peugeot or Citroen base vehicle.
Geoff
My normal Peugeot Boxer has trailer towing capacity of 2,500kg and as you say all dragged from the front.It's Fiat engines, 2.8JTD. However seems bizarre to me for it to have the high payload it does ie: 4,500kg & 5,500kg Gross Train (giving a permissible 1000kg trailer Weight), 2 rear axles and have it all being dragged from the front?
Well this not a lorry with twin wheeled drive, plus sophisticated air suspension to maintain sufficient weight on the drive axle.Check out a lot of lorries, tag axle AND rear wheel drive
Can you please elaborate how air suspension, sophisticated or not can possibly move weight to the drive axle??plus sophisticated air suspension to maintain sufficient weight on the drive axle.
Think you have to quote the whole of bigalw35 and not just the part you want to.Well this not a lorry with twin wheeled drive,
Absolutely no reason why a moho could not be rear wheel drive to "front back axle" with a free running 3rd "rear rear axle" for extra load bearing.Check out a lot of lorries, tag axle AND rear wheel drive, drive is generally on the front axle of the two
Simply by reducing the air pressure at the additional axle air bags. They also often have a dump control for use if traction is lost at the drive wheels. this either removes all air pressure from the additional axle or indeed lifts it off the ground completely.Can you please elaborate how air suspension, sophisticated or not can possibly move weight to the drive axle??
Grint. I certainly can confirm that the B754 (which is the same layout both externally and internally as the E690), is definitely FWD on a Fiat/ALKO chassis.JockandRita will confirm it’s definitely FWD.
donkey . Thanks for the reply and what you are saying, however I really do struggle to see how what you are saying would indeed work....Simply by reducing the air pressure at the additional axle air bags. They also often have a dump control for use if traction is lost at the drive wheels. this either removes all air pressure from the additional axle or indeed lifts it off the ground completely.
Geoff
More applicable to HGVs than to MHs. IIRC, it's all done by load sensing valves, causing the tag axle to raise or lower.Your quote " or indeed lifts it off the ground completely" really does have me confused.... Sorry![]()
Yes I understand the concept on a lorry, but I was referring to the quote by donkey who made it abundantly clear to bigalw35 that he was not refering to lorrys but mohos. And i was just enquiring how air suspension on a motor home could raise an axle of the ground??More applicable to HGVs than to MHs. IIRC, it's all done by load sensing valves, causing the tag axle to raise or lower.
If struggling to get up a ramp with a 6 x 2 Tractor unit with a loaded trailer, I can raise the tax axle thereby giving me a better grip with the drive axle. Once clear, I can either lower the tag axle manually, or let the system do it automatically, as it senses the load again............................none of which is applicable to MHs.
Cheers,
Jock.![]()
I thought that you would point out that is a tandem not tag JockGrint. I certainly can confirm that the B754 (which is the same layout both externally and internally as the E690), is definitely FWD on a Fiat/ALKO chassis.
We up plated ours from a GVW of 4500Kgs, to 5500Kgs, with a total train weight from 5200Kgs, to 6500Kgs.
All legit and above board.
There is one A Class MH on a Mercedes/ALKO chassis, which does have RWD on one of the rear tandem axles, but I can't remember which manufacturer it is.
Jock.![]()
OK it might not lift an axle but a 4 or 6 channel air bag system could drop the pressure in the non driven axle thereby ensuring that the driven axle had full contact on rough ground etc, the trouble would then be that the one axle and tyres would then be overloaded so most likely not a good idea.
I normally would Martin, but some folks just don't take any notice.I thought that you would point out that is a tandem not tag JockI believe the tandem, or does the one driven axle make it a tag even though it doesn't lift ? anyway I think it was Frankia had the exclusive for a year but never progressed with it.
In that scenario Martin, I would expect some electrickery/load valves to be fitted, which would kick in at a detected speed of 10 -15 MPH for example, which would then balance out the axles to take the load evenly, keeping things safe and legal.OK it might not lift an axle but a 4 or 6 channel air bag system could drop the pressure in the non driven axle thereby ensuring that the driven axle had full contact on rough ground etc, the trouble would then be that the one axle and tyres would then be overloaded so most likely not a good idea.
I don't think so Jock, but you are right it would need to be properly managed.I normally would Martin, but some folks just don't take any notice.
A tag axle trails a driven axle, where most, (but not all), can be raised or lowered. The twin axle set up on a Fiat/Peugeot/Citroen ALKO chassis, are tandem axles, as neither of them are driven.
A mid lift axle, is one which precedes the driven axle, and invariably can be raised/lowered either manually or automatically.
Is there such a system on a MH?
Cheers,
Jock.![]()
No, I didn't think so either Martin.I don't think so Jock, but you are right it would need to be properly managed.
My thoughts entirely mate, front wheel drive just doesn't seem right. Thus I'm looking for confirmation that it's the 2nd Axle is actually drivenCheck out a lot of lorries, tag axle AND rear wheel drive, drive is generally on the front axle of the two
CorrectCheck out a lot of lorries, tag axle AND rear wheel drive, drive is generally on the front axle of the two
Your moho is a Ducato up to the B pillar where the seatbelts are attached. All the drivetrain finishes there too, the Alko chassis is bolted on by Hymer, the wiring, rear brake system and the exhaust hung and that’s it.My thoughts entirely mate, front wheel drive just doesn't seem right. Thus I'm looking for confirmation that it's the 2nd Axle is actually driven![]()
Hi. Are you actually still thinking this vehicle is anything other than front wheel drive? What or why made you think it was anything else? Did the seller indicate that it was rear wheel drive?My thoughts entirely mate, front wheel drive just doesn't seem right. Thus I'm looking for confirmation that it's the 2nd Axle is actually driven![]()
No, sorry, definitely front wheel drive. The 2 rear axles, tags, call em whatever are dragged along. I’m not aware of Fiat ever making a rear wheel drive Ducato unless someone can tell me differently.My thoughts entirely mate, front wheel drive just doesn't seem right. Thus I'm looking for confirmation that it's the 2nd Axle is actually driven![]()
