hymer abs light on (1 Viewer)
tony drury
4
arboleas spain
a class
three years
I hope someone can help me please. I have a Hymer 1992 310d 555s. My ABS light has come on. I explained to my mechanic I heard a noise prior to the light coming on, he thought that it may have been the ABS pump due to the noise. He changed the pump but the light is still on. He has carried out a resistance check on the front and rear sensors, the 2 front sensors were ok but 1 of the rear sensors was high. i am told the sensors are the problem.
The Chassis No. WDB 6024 111P 171392
Does anyone know where I can obtain rear sensors?
Merecedes Part Numbers.
Left: A 000 540 1117
Right: A 000 540 1017
Bosch Part Numbers:
0265 001239
0265 001240
I am also looking for an English Manual for my Hymer.
Thank you
May 20, 2009
785
865
Haute Vienne, France
Bosch Part Numbers:
0265 001239
0265 001240
Thank you
Spose you could try Mercedes dealer for the parts.:thumb:
MikeD
3,936
3,697
London
IH PVC
Fault lights on dash
I am no expert on these things but:
You don' t say whether you have plugged a fault code reader into the vehicle.
If it applies you really need to get someone to plug in a OBD reader to the vehicle and find out the fault code.
It may well be something less serious than you think.
The computer in the vehicle checks everything every time you start but may not reset the indicator light immediately after you replace something.
You could be replacing all sorts of things before it goes out.:thumb:
43,331
49,483
as the sensors are in an extreme environment it may be worth removing the faulty one/s and giving them a clean as they can be affected by road dirt...nothing to lose except a little time.
it does take a short while for the warning light to clear once the fault is fixed...
mine, Chrysler 300c car which is basically a re-bodied mercedes E class , took around five mins driving before the light went out.
the faulty sensor wont affect braking except you wont have the anti-lock function.
43,331
49,483
1993 year wont be OBD compliant..
OBD didnt become mandatory until 1996 at the very earliest and that was on American vehicles.
OBD for european diesels became mandatory in 2004
MikeD
3,936
3,697
London
IH PVC
Pappajohn you are correct
You are correct I had a quick search on internet and came across this:
mercedes 310d i have a hymer motorhome based on a 1992 mercedes
i have a hymer motorhome based on a 1992 mercedes 310d l/h/d the abs light is on is there a plug in system to diagnose faults and where is it likely to be positioned
[FONT=&quot]Additional Question Details[/FONT]
[FONT=&quot]Country: United Kingdom
Make: mercedes
Model: 310d
Year: 1992
Engine: 2.9
Already Tried:
checked all sensor[/FONT]
[FONT=&quot] [/FONT]
[FONT=&quot]Posted by Diagnostics Engineer 569 days and 9 hours ago. [/FONT]
[FONT=&quot]Expert's Answer [/FONT]
[FONT=&quot]Diagnostics Engineer : [/FONT]
[FONT=&quot]Hi,
Please let me know the VIN of your van.
Regards,
Stan[/FONT]
[FONT=&quot]Customer : [/FONT]
[FONT=&quot]vin no WDB6024111P257666 engine no 60294010232806[/FONT]
[FONT=&quot]The control unit does not have a fault memory. The only way to diagnose is to check all of the components one by one with tester.[/FONT]
[FONT=&quot]The most common cause for ABS failure is the overvoltage protection relay's dry solder joints, failed brake light switch or bad wheel speed sensors.[/FONT]
This was on justanswer.com :Blush::Blush::Blush::Blush:
joeyo
4
Hi any idea on the abs ring part no or how many teeth it has, thinking of retrofitting abs onto a merc 410
thanks
43,331
49,483
thanks
Brave or clever......
Where are you going to fit the tone rings, sensors, pump and electronic control unit ?
Tone rings are usually within the hub bearing carriers
The sensors fit in dedicated casting holes in the same.
Pump would be the easy part after re-piping all the brakes.
How will you wire the control unit as they are wired from the PCM
joeyo
4
dont know yet, just doing research as theres an abs unit for sale, i belive the ecu is pretty much just the glowplug relay and dash lights on these, the abs seems to have all its own circuitry on board, yes sensor and ring mounting might be tricky but if i know the ring holes i can fab up something to fit not necessarily in pre cast holes
43,331
49,483
The ABS will have its own circuitry but its still controlled by the PCM.
The hub/driveshaft won't have the necessary mounting surface for the tone rings and are easily damaged.
they are a tight interference fit on the hub/shaft for a reason.
I can't see any possible way to overcome this and to be quite honest it's a waste of time trying....BUT..it's your choice of course.
Oct 29, 2008
5,070
5,973
West Yorkshire
Its a 1992 van. Pre computers
11,955
16,570
I've not braked hard enough, ever, to affect the ABS in the motorhomes I've owned. Prior to that, and in any vehicle, I can count the number of hard or emergency stops I've had to perform on my fingers. On that basis, and in 50 years of driving, it's wasted on me. So, and this is a serious question, what has happened to the OP to convince him or her of the need to retro-fit ABS?
joeyo
4
same reason anyone would want abs, to help steering and reduce stopping distance in emergency stops and on loose surfaces, you obviously drive on good roads, the roads around here often are strewn with mud and horse shit for most of the year so loosing traction under breaking doesnt take that much effort. Have driven a 308 for years without problem or need for abs but saw a 410 abs for sale so thought i would see what it would take to upgrade, mayb its more trouble than its worth but if the info is out there id be interested to know.
43,331
49,483
ABS doesn't shorten stopping distance but it does allow you to steer safely (within limits) on loose/snowy surfaces as opposed to sliding with the wheels locked.
More of a controlled skid than an 'oh shit !' skid
joeyo
4
of course it decreases stopping distance, more so on good surfaces, apparently it can increase stopping distance on very loose surfaces and snow compared to locking wheels but i think the ability to have some control outweighs the increased distance
i have driven both with and without and definitely prefer to have it for those rainy days
43,331
49,483
You say the roads around you are generally covered in mud and horse crap....read on.
ABS generally offers improved vehicle control and decreasesstopping distances on dry and slippery surfaces; however, on loose gravel or snow-covered surfaces, ABS can significantly increase braking distance, although still improving vehicle steering control.
And if you read again I said....
Cooldude
29
16
Midlands
Last week the electronic brake failed on our just 3 years old Peugeot 3008. We also has ABS messages. Called out breakdown and he discovered the offside rear speed sensor was not working. Took it to garage, all OK now, a new £50+ sensor was fitted, and all issues, warning lights on dash now resolved. They told us that they also found that the wires to the sensor were frayed. As they were not protected, the continuous up and down movement at the rear, whilst driving frayed the wires on the metal sheet bodywork. Thanks for the common sense build protection Peugeot! I wonder when the wires to the speed sensor are going to fail on the other rear wheel! - Just a thought it could have been the wires all along. Perhaps the mechanic should have checked the wires before they installed the new £50 sensor! Rant over!
Hey Ho! - I am going to lie down now!
Grumpy Pete.
MikeD
3,936
3,697
London
IH PVC
ABS will increase stopping distances - it just gives you steering control.
When ABS occurs you will be surprised how much the braking forces reduce. It's quite frightening when the vehicle just stops slowing down as you expect.
