How to test alarm/immobiliser.
Norfolk
Autotrail Savannah
Since Jan 2014
Just purchased an Autotrail Savannah 2011 and would like to know how to check if the alarm/immobiliser is working properly.
Any ideas how to test this. Thanks.
Is that setting the alarm from inside and opening door from the inside.
There should be a fob sequence to do both. Close the van from the outside. Activate alarm and open a door.
Plus inside the same but alarm should not activate when you move around, only on opening a door. (y)
You need to check your alarm instructions.
Thanks. Will try it tomorrow when the neighbours are up. 😂
Maybe maybe not, the Eddievanbitz strikeback has two modes one when we are away from the MoHo and the second setting is when we in residence so mode 1 the alarm would go off if you move inside the MoHo Or undo the doors etc. Mode 2 opening the doors etc will set the alarm off but not if your moving around inside. Neat eh 👍
