Don Quixote
- Jul 29, 2012
- 2,965
- 5,265
- VW T6 Campervan
- Not long enough, but a little common sense helps..........
What flashing light?
The 5A fuse is a standard blade fuse. The 50A fuse is a Midi fuse, you may need to go to an automotive electrics supplier for these.
View attachment 450319![]()
MIDI fuse (30 - 200 Amp rating)
Range of MIDI fuses Bulk deals available for packs of 100 1000. The MIDI fuse is available in the following amperages 30,40,50,60,70,80,100,125,150www.altecautomotive.co.uk
Where are the relay boxes likely to be located, near the charger/ leisure battery?Second light in from the left on the horizontal bank is the charging light for BOTH. If it is flashing from memory that shows a fuse has blown in one of the two Boite relais securite = Safety relay boxs
yesWhere are the relay boxes likely to be located, near the charger/ leisure battery?
6yrs later, today this thread saved my backside. Many thanks to Irnbru and all who contributed. I am "That special kind of genius" who managed to blow the 5amp fuse in the "Bois Relais". I'm so happy I've just renewed my subs!Ok from previous threads regular viewers will know we have been having ongoing battery problems.
Today we had a new starter battery fitted but the control panel is still showing battery as flat, 1 notch and flashing...any ideas?
