- Apr 6, 2019
- 6,238
- 12,961
- RV
- FourWinds Windsport 6.8L V10
Well I finally tackled the Ducato (230, MK2) "stupid" headlamp adjuster mechanism. Replacement part from Opie Oils is slightly different part number and lots of retailers say it is Left hand drive only.... That is nonsense!
It is a bit fiddley and requires some blind work pushing parts through the bulk head hole but got there in the end. I hear this might be a future MOT failure do take note my friends.
In brief.
Battery out.
Driver's lower dash out.
Old switch on upper dash out.
Loosen off some pipes near headlights to allow better access if needed.
Old units have ball attachment onto mechanism, spray with lubricant and pop off in situ. Twist mechanism and push away from front of van to line up three plastic protrusions and pull mechanism free.
Both adjusters have to fed through engine bay and pushed pulled through bulk head to driver's lower dash.
Same in reverse BUT in order for dashboard switch to line up correctly you need to feed adjusters up and over a white cross member directly behind dash and not underneath it or you will have to start again.
Round pins pop back into plastic arms on headlamps and require lining up so the one grooved protrusion is to the right... Push and twist to lock.
Hope that helps some others.
I removed headlamp as I wasn't sure how to release the ball end of the hydraulics but not needed. I could also see where the old units crack and leak all the fluid out where pipe meets unit.
In brief.
Battery out.
