How to black out windows
bennyyorkie
Van conversion
Hi,
In our van conversion we have quite a few windows we need to black out and just wondering what are the best ways to do it. I've heard there is a spray on method, a stick on and companies who will do it for you.
Also, I wonder is the black out just like black out windows in a car or can they be done to also block out light for sleeping?
A bit clueless on this Im afraid.
many thanks for your help!
I read somewhere recently that one method is to spray the glass on the inside with a satin black paint then stick insulation to it and then board over. It sounds like a reasonable way to do it as long as the windows are the non opening kind.
Don’t forget to tell your insurance company about the change.
Round here it’s just the drug dealers that have blacked out windows.;)o_O
I would go along with the firs reply if you aren't going to look through them why have the penalty of the heat loss/gain it would be a bit like a blacked out conservatory a bit pointlell leaving it a glass.
Personally, if intent on doing, I would use the stick-on method as opposed to paint-on method, whether DIY or professional , As much easier/quicker to remive if you change mind
Thank you so much for your replies. I will be making some calls tomorrow, looks like the stick on version will suit best! thanks again
Yes window tint film would be best. 'Limo black' 95% light reduction legal from 'B' pllars back for UK vehicles.
window tint film will cut most of the light, but not all. vinyl vehicle wrap is cheap and in a choice of colours and will block all light
If you want privacy then window tint is not the solution as it only works when it is lighter outside than in.
ie: at night with your hab lights on it allows people on the outside to see in as if it was not there at all.
Just buy a few metres of 600mm wide 5 to 7 year calendered vinyl off ebay, very cheap and easy to apply with a little practise.
retired sign manufacturer (vehicle livery etc')
Colin
View attachment 357266View attachment 357267
Colin
Thanks so much for that. I've had a look on ebay but to be honest, i'm not quite sure what I'm searching for. Would you be also to add a link etc. I wonder do you mean the sticky tape that is used in the photos above for the window signage? Sorry for the stupid question!
Hi Benny
Yes we used the same vinyl for the windows as we used for the body. There are lots of different types used for specific applications but the general most used would be the 5 to 7 year life as stated
Here is a link to a 3 to 5 yr' seems a bit expensive but of course they are selling very small amounts.
https://rover.ebay.com/rover/1/710-...0001&campid=5338547443&icep_item=320851322344
This link is to one of my old suppliers check out his clearance range, im sure there will be something there for you.
Colin
I don't "get" the obsession with privacy.
Surely when you do the dance of the seven veils you want your neighbours to appreciate the artistry.
It is simple here. Tinted windows reduce the sun effect & help keep the temperature lower especially when travelling in summer sun.
