1st service was missed due to me misreading manual. (By 30 months)
Durley Garage did a full service (fluids filters Inc brake fluid) £442.68 Inc vat.
I think Adams Morey are now over £800 since their labour rates went up to £115 +vat per hour.HOW MUCH ******* 1st service on my Carthago Malibou . ( 2 years or 30k miles)
Had a quote from Vospers main dealer for the 1st service on Fiat Ducato mileage 15k.
£675 !!!
Colyboy
They are only required to do it if there is a problem but some dealers always do it Adams Morey do.The only value a Fiat Pro garage might add is they could put a newer flash of the ECU firmware on there. But I'm not sure if they do that unless there's a specific issue.
I would have thought that "if it ain't broke, don't fix it" applied, no? Flashing takes time and isn't risk free.They are only required to do it if there is a problem but some dealers always do it Adams Morey do.
Probably worth it if you have a Comfomatic or auto box, they charge around £200 if you have the updates done seperately.
According to hand book fist service is 10k miles and the bit I missed is or 12 months which ever soonerWhat?? So you didn't have a service for 4 years? (24 months +30 months??)
Or you mean you missed it by 6 months? (30 -24)
Try Chelston Motorhomes. Just had mine done there for £475. Fiat Professional workshop and very happy with the service there.HOW MUCH ******* 1st service on my Carthago Malibou . ( 2 years or 30k miles)
£675 !!!
Colyboy
Is the first service not just oil and filters?
I’ve bought vans for less than that !HOW MUCH ******* 1st service on my Carthago Malibou . ( 2 years or 30k miles)
£675 !!!
Colyboy
Book states t1st service to Inc Brake Fluid change.
Van had been booked in at a Fiat Pro in Nov for mot and service. Left it with them all day when came back @ 4 o'clock "Oh not started it yet"
Told them just mot it and I'll make other arrangements.
Not being funny, but you really need to consider the difference.Thanks for all your comments. Just had a quote from my local garage £256.
Colyboy
May depend on garage, I asked/nagged and they assured me part of the service was linking to Fiat computer that does all the other bits like updating oil usage, service history in the ECU and updates. I checked, they did. Can't say for all, but always ask - it does fix issues that are discovered! (Our MY20 had an update in early 22)The only value a Fiat Pro garage might add is they could put a newer flash of the ECU firmware on there. But I'm not sure if they do that unless there's a specific issue.
£675 !!!
Colyboy
Colyboy, try Rex Saunders at Milton Damerel near Holsworthy, a Fiat Service centre, just had my 2nd service, £453 Inc vat, and MOT for £54. Great farm cafe just down the road. Tel:01409 261212HOW MUCH ******* 1st service on my Carthago Malibou . ( 2 years or 30k miles)
£675 !!!
Colyboy
there are just as many with full Ford service histories with junked engines from the wet belt. & Ford replacing foc. It isn't the oil but the belt system that is a nonsense.Funny how Ford only use a specific blend for the ecoboost and that protects the belts,
The parts list (which you can't get online cheaper) was more than that. Sure, cheaper filters, missing fuel filter swap, cheaper oil will all keep the price down.
Not least, your local garage is very unlikely to update the software on the van. (Software/systems are, I believe, only available to Fiat Pro specialists). Ours made a huge difference (I was aware of a drivability "issue" that went after the service). Many Euro6 (non ad blue) have been serviced in local garages and not had software updates leading to massive failures later on - and updating then is too late as the fueling maps caused damages in DPF, injectors etc etc).
(Not limited to Fiat, many Ford Ecoboost engines blow due to wet cambelt deteriorating and bits blocking the oil pickup causing oil starvation. Funny how Ford only use a specific blend for the ecoboost and that protects the belts, but the cheaper garages will sling in any "match" rather than specific). etc
Ours was in the workshop >3hrs (tracker) and all work was better than expected.
The 4/5 year service should be >£1k as you will need a cambelt.
Surely spending this much on a van you budget for maintenance?
Personally, knowing what I do, if I saw a van with non Fiat Pro service for sale, I'd walk away as you have no idea on the long term implications of missing updates on time (as many owners of the earlier vans now know)
Below is FYI. Parts are, IMO, v fairly priced and not huge mark ups based on what I could get online. This was a Fiat Pro specialist who only does motorhomes/vans (Chestleton motorhomes), and they did update the ECUs (I dumped them pre/post due to a strong distrust of garages lol). It will be going back for a "mini service" at 3yr (as have 3y warrantee, so want it checked/MOTd by someone who knows the vans inside out) - and will have fuel filter changed again (keep the diesel happy!)
edit: The noise investigation happened after ECU updates/service and went away lol - one of my drivability issue was lack of low down torque that the new ECU software fixed, so may've been related etc.
This has already been covered but Fiat has made several errors on the way to Euro 6 perfection. Needing ecu updates since 2017.I would have thought that "if it ain't broke, don't fix it" applied, no? Flashing takes time and isn't risk free.
