Really impressed with that quick answer Lenny. can you please explain for us numpties how you work that out17 amps at 12v + 10% for inverter inefficiency so 19 amps, if it's a cheap inverter allow 15%.
1 amp at 230v. So on the other end of your invertor, it'll pull 12v and nearer 20 amps.So i wasn't reading it correctly then I thought it was less that 1 amp (0.85A)
thanks a bit too heavy to run that 24hrs per day1 amp at 230v. So on the other end of your invertor, it'll pull 12v and nearer 20 amps.
230v x 0.85 amps (plus ~10% for the inefficiency of the invertor) = 220 wattsthanks a bit too heavy to run that 24hrs per day
Thanks, that explains a lot230v x 0.85 amps (plus ~10% for the inefficiency of the invertor) = 220 watts
So it's a large, but not impossible power draw.
My brother takes a similar ice maker camping. He runs it for an hour or so in the late afternoon after the solar has charged the batteries. There's then enough ice for that evening's drinks. He does have quite a lot of solar panel though.
If it's sunny (which will correlate with the G&T requirement), you'll probably find that with 300w, your lithiums will be pretty much charged by late morning. Those photons will be going to waste. You could probably switch the ice maker on and run it until mid afternoon and still have your batteries maxed for the evening. Personally, I'd take it and try it.Thanks, that explains a lot
I have 200 ah of lithium and 300 wats solar. I was hoping to take it to the Norfolk show to keep the G&T cold... but a bag of ice it is then (If i can buy one)
Best thing to do is just try test running it. My little work top freezer runs at 4 amps off the 12v battery in the shed.am i reading this correctly... does it really use so few amps. i am hoping to use this via my inverter, How many amps will it require
thanks
I (AMPS) = P(WATTS)/V (VOLTS).So i wasn't reading it correctly then I thought it was less that 1 amp (0.85A)
POWER is constant so as the volts come down the current draw(amps) goes UP.I (AMPS) = P(WATTS)/V (VOLTS).
POWER is constant so as the volts come down the current draw(amps) goes down
So at 12v, 220W would require 220 / 12 = 18A.230v x 0.85 amps (plus ~10% for the inefficiency of the invertor) = 220 watts
Only if you've got a voltage regulator, usually with a lower voltage supply the element will consume less power... But you already know that of coursePOWER is constant so as the volts come down the current draw(amps) goes UP.
