How do I replace the cable in these?
Cardiff, UK
Since 2016
Anyone know?
Alternatively, what are they called so I can source some replacements?
Probably with these type of tools to depress barbs
Also check YouTube
Look like "mate n lock" connectors if you do t want to buy the removal tool you can normally get the pins out with a jewelers screwdriver. New pin crimp well with a crimp tool for non insulated push on connectors.
Are they Molar connectors or Mate n lock?
Did you mean Molex? I guess so going by what autocorrect was trying to do to my typing. 👍🏻🤔🤪
You can get molex tools for assembly or disassembly.
I've just compared them to both the suggestions above and they are similar but not the same. They are German so not sure if that helps? I may just chop them off and use something else, Wagos maybe.
Just cut the old wires and use butt solder and heatshrink connectors to attach the new wires if you can't source one off plugs
Yes, probably the best plan. Probably be expensive just for one of each anyway. 👍
Your molex examples aren’t typical ones but I bet £5 of someone else’s money they’re molex pins and housing 🤣
Here’s a random male & female molex housing and pins unassembled (well, pre-assembly)
