Housing fault
NorthumberlanJ
Autotrail Arapaho
The housing control is bleeping and showing
50L. Full when the motorhome is completely off and closed down it’s intermittent I can’t get anyone to look at it until 30/09 I’m in north Northumberland... any ideas anyone ?
Thank you in advance
I assume you are talking about the hab side, if so disconnect that side of things to see if the panel resets it's self.
What system is bleeping? Starter battery, habitation battery, fresh water, waste water - a bit more info required before any real advice can be given
It says soil full flashing on the display but there is nothing in the waste Water or cassette I took the cassette out and seen a pink fuse looks connected to wires?
It can do that sometimes if the level float is jammed up, take the cassette out give it a good clean and try again.
Or if you have small hands a pair of gloves and down throught the hole. used to get toilet roll wound round the float preventing it from going back in place.
