Hook up flap (1 Viewer)
Easyliving
956
2,021
Norfolk
Since 2011
I managed to break mine a couple of years ago. Bought a replacement from Amazon, can't remember details now but it must have been cheap. Easy to fit, but get one with hinges.
Paul
RogeTeri
RogeTeri
367
165
Abrantes, Portugal
February 2013.
Thanks Paul. Do you remember the name of this part? Motorhome hook up flap replacement sounds too complicated
Feb 9, 2008
4,093
5,910
SW Scotland
LP Coachbuilt
Since 2008 after caravanning for 20 years
I got fed up fixing the spring on the flap I replaced thr whole thing. Wasn't expensive.
RogeTeri
RogeTeri
367
165
Abrantes, Portugal
February 2013.
Thanks for the advice. If I replace the unit will I need an electrician? Or is it something easily fitted by a well meaning amateur?
M-J
Jan 15, 2019
2,613
6,272
Cambridgeshire, UK
Rapido 986F
Getting there!
If it’s just the cover/flap it’s only a matter of removing the long pin in the top hinge and changing over.
I have been thinking about doing mine as it’s started to yellow a little.
Minxy
32,656
66,564
E Yorks
Carthago Compactline
Why are you replacing it? Is it bust or just discoloured?
Minxy
32,656
66,564
E Yorks
Easily sprayed 'in situ' if you mask off round it. We had one on a previous MH which discoloured so we sprayed it matt silver to match the decals.
M-J
Jan 15, 2019
2,613
6,272
Cambridgeshire, UK
Rapido 986F
Getting there!
True but cheaper to replace at less than £10 by the time I have purchased the paint and time of doing it.
Peter JohnsCross MH
Jan 5, 2008
9,617
6,194
East Sussex
Autotrail
Easyliving
956
2,021
Norfolk
Since 2011
I found the one i got from Amazon. Type in 'caravan motorhome replacement cover' and it's the first one listed, sold.by Pennine Leisure Supplies' cost is £12.01, more than i thought it was.
If I remember rightly I got fed up with trying to repair the old broken one so lashed out the 12 quid. Really simple to fit.
Paul
two
Aug 4, 2011
4,903
4,573
West Midlands
A-Class Fiat
There are several different types. Mine was easy to find and replace.
I could hear and see it flapping as we travelled along. Couldn't stop because we were on a motorway. It went quiet after a while and I forgot all about it. At the next stop I found that the damn thing had come off!
Oct 11, 2016
1,316
2,197
Bognor Regis
Bailey Adamo 69-4
6 years
Did mine. 2 minute job.
Reactions: M-J
smiffy64
77
59
Fife, Scotland
Coach built
Newbie
Yes they are cheap to replace, but I think they are simply inadequate(n)
I am sure I speak for a lot of us motor homers and caravanners, where we start off on our travels and notice the flap flapping (and the water inlet is just as guilty) and looking like it is going to go flying at any second. Then we have to stop at the earliest inconvenience, often having to come off the road.
So why the hell do they design them to be held by brittle plastic that is part of the moulding? They either get more brittle over time, slightly warped(like mine) and sometimes refuse to click in place. I never get that reassuring click from a well designed mechanism that befits a seriously expensive vehicle. It seems to me the most annoyingly 'cheapest' most ill designed piece of crap on my motorhome.:mad:
And relax....Rant over:whistle:
Seriously, why are they not made of metal, with a either a powerful magnet or a toggle catch? Making them only open WHEN WE BLOODY DECIDE:mad:
Probably also with a waterproof grommet at least on the EHU flap. I have found my EHU socket flooded after washing my MH quite often.
If I have got to start up my own company who makes these things, I WILL get this sorted!(y) And 50 pounds would be acceptable!
TheBig1
17,630
43,296
on top quality caravans some have a lockable cover that can be used to secure the hook up cable in place too
Sep 22, 2009
473
333
nottingham
5 years
The cover over my desiel fill cap is cracked on the hinge side so when it's open I think it may drop off. Is still holding when it's shut but have to make sure everything is in line before clicking into place
Feb 2, 2015
2,284
7,264
Shropshire, UK
A motorhome!
we are still learning
We have just fitted one of these
£23 and well worth the swap. No flapping about and the colour matches the van!
Kev
Aug 11, 2018
105
223
Europe
€6 Peugeot Boxer van conv
50 years inc camping and caravanning (and I'm not much older than that)
I'm building my own, and these ones are about the best (as you can see by the price!). That's what I have fitted, and they are available in different colours (one here in black and cheaper!) and there is a matching water fill point.
But, they are slightly bigger than normal, so likely not to be a straightforward swap-out.
two
Aug 4, 2011
4,903
4,573
West Midlands
A-Class Fiat
The newer ones are magnetic and seem to be pretty good at staying closed. They do, however, seem to attract a lot of metallic road dirt...
I've even managed to loose a lockable water cap that I had not put back correctly. An expensive mistake if you want to continue with matching keys all round.
Nov 4, 2014
1,407
999
blackpool
Just looking
I have just had electric and water covers replaced .at HARTLEYS MOTORHOME In Kendal same time of habitation check. due to them being very brittle £22 each. Next time I will use 2sided tape
Feb 2, 2015
2,284
7,264
Shropshire, UK
A motorhome!
It was actually easy!
Took my old one of and the new one fitted in the same hole and lined up the two top holes exactly. The bottom two had to be drilled to suit. That aside apart from Autotrail not allowing enough cable for removal and refit...all was quite simple. A little bit of Sikaflex and all was done in no time.
Kev
