Easily sprayed 'in situ' if you mask off round it. We had one on a previous MH which discoloured so we sprayed it matt silver to match the decals.If it’s just the cover/flap it’s only a matter of removing the long pin in the top hinge and changing over.
I have been thinking about doing mine as it’s started to yellow a little.
Did mine. 2 minute job.If it’s just the cover/flap it’s only a matter of removing the long pin in the top hinge and changing over.
Yes they are cheap to replace, but I think they are simply inadequateI could hear and see it flapping as we travelled along. Couldn't stop because we were on a motorway. It went quiet after a while and I forgot all about it. At the next stop I found that the damn thing had come off!
I am sure I speak for a lot of us motor homers and caravanners, where we start off on our travels and notice the flap flapping (and the water inlet is just as guilty) and looking like it is going to go flying at any second. Then we have to stop at the earliest inconvenience, often having to come off the road.
So why the hell do they design them to be held by brittle plastic that is part of the moulding? They either get more brittle over time, slightly warped(like mine) and sometimes refuse to click in place. I never get that reassuring click from a well designed mechanism that befits a seriously expensive vehicle. It seems to me the most annoyingly 'cheapest' most ill designed piece of crap on my motorhome.
And relax....Rant over
Seriously, why are they not made of metal, with a either a powerful magnet or a toggle catch? Making them only open WHEN WE BLOODY DECIDE
Probably also with a waterproof grommet at least on the EHU flap. I have found my EHU socket flooded after washing my MH quite often.
If I have got to start up my own company who makes these things, I WILL get this sorted! And 50 pounds would be acceptable!
The external cover (flap) for my electricity hook up needs replacement. Any ideas on who can supply replacement? Thanks
I'm building my own, and these ones are about the best (as you can see by the price!). That's what I have fitted, and they are available in different colours (one here in black and cheaper!) and there is a matching water fill point.We have just fitted one of these
£23 and well worth the swap. No flapping about and the colour matches the van!
But, they are slightly bigger than normal, so likely not to be a straightforward swap-out.
