HEOSwater Universal Water Connector £19.98 Funster Discount Code (1 Viewer)
Wombles
10,808
11,132
SW England
Van Conversion
A few years now
Knowing how popular the HEOSwater was earlier this year & seeing lots of stock of the Universal model on Care-avan stand we negotiated the recent NEC Show price of £19.99 for Funsters plus free delivery :) To get this offer & 10% discount on all the products on the website go to http://www.prideandjoycarcare.co.uk...er-Filler-Cap/c/21265076/offset=0&sort=normal & input code MOTORFUN at checkout.
dscf0031-jpg.129577
WynandJean
6,670
3,303
West Midlands
Bailey Autograph 682
Since 2010
We've had one of these for years. Excellent idea. However I attached a short piece of hose to the inside of ours to prevent dribble. It looks like they have taken that on board and the new model looks like it has a piece of pipework inside for just this purpose.
Recommended.
Wyn
Cal54
3,806
62,034
Southport, UK
Leisuredrive Renoir
Since 1996
Great bit of kit. If I didn't already have one I would be jumping at this offer. For solo travellers they are an essential piece of equipment.
Wombles
Wombles
10,808
11,132
SW England
Van Conversion
A few years now
Glad this offer is of use to Funsters :) This 10% discount code is valid until 30th November & works on the other items (hoses, cleaning products etc) on the website too.
Wombles
Wombles
10,808
11,132
SW England
Van Conversion
A few years now
For anyone who wonders what this funny looking gadget does :wondering: - it doesn't replace your existing cap but is a device to use when filling your water tank with a hose. It makes it easier as don't have to hold the hose in the tank & will vent once full so excess water will come out around the filler cap which is helpful if your tank doesn't have a built in overflow. There used to be various designs of these & it took us three attempts :wasntme: to find the right one but now the Universal should cover most variations apart from the smaller Fiamma type.
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Never been a fan of discounts
I just do cheaper BROKEN LINK
But you got me with free delivery
Wombles
Wombles
10,808
11,132
SW England
Van Conversion
A few years now
Good photos & fitting guide on that link (y) but p&p at £4.95 is a lot unless buying more.
Wombles
Wombles
10,808
11,132
SW England
Van Conversion
A few years now
Although the HEOSwater works well as it is Mr Womble has now added a small piece of hose (just pushed on) so that the water goes directly down into the water tank - this was an idea from fellow Funsters putting their heads together under @Tootles awning on this years Bagwell Rally :) There is a chance that the short piece of hose could come off into the tank but normally easy to get to. He cut off a piece of (food grade) tubing from one of these:
Wombles
Wombles
10,808
11,132
SW England
Van Conversion
A few years now
There must be a reason for doing this but I can't see the point ... I would be interested to know.
The idea was as a result of a Funster at the Bagwell rally (sorry can't recall name) having a split in the top of his corrugated tube filler pipe so he had to fill by putting a normal hose down past this point so didn't think he could use his HEOSwater anymore although he wanted to so after some discussion the tube idea evolved. He tried it & it overcame his problem :) Mr Wombles thought it might improve filling using ours too as the add on tubing directs water downwards rather against the back of the corrugated tube then down - it does seems to work better & maybe less chance of wear & tear on the corrugated pipe? Really not necessary though as HEOSwater still works well without it.
TerryL
6,187
8,189
North East
Low Profile
Been looking for one of these for ages - just ordered. Thanks for the discount code.
Deneb
1,598
2,334
Europe
PVC
Yes, thank you. Arrived on Wednesday and I used it to part fill the tank yesterday. I think I need to fit the flat gasket that was included in the package as it did dribble a little bit from around the cap. Comparing it with my existing cap suggests that is the only difference.
It did the job though, and it's handy to be able to just snap the hose connectors on at both ends and not have to keep holding the hose in.
Edit: As your post prompted me, I've just popped out and fitted the flat gasket, which the instructions say is for tanks with a built in overflow. The cap now fits much more securely with an obvious seal against the filler inlet, so I'm confident that is all that was required.
TerryL
6,187
8,189
North East
Low Profile
Got mine too. Tried it on the filler, fitted okay but I didn't put a hosepipe on it (I was actually just winterising the van). Looking at above post though looks like I might also need to fit the washer, it's only a few seconds job.
Wombles
Wombles
10,808
11,132
SW England
Van Conversion
A few years now
Fun discount code still valid - runs until 30th November :)
Wombles
Wombles
10,808
11,132
SW England
Van Conversion
A few years now
Still time to get this as a Xmas present for the motorhome owner who has almost everything else :rolleyes:
Wombles
Wombles
10,808
11,132
SW England
Van Conversion
A few years now
I just tried MOTORFUN and it said code not valid.
Thank you for letting me know - I just tried it & got the same - bit odd as meant to run until end of this month o_O so will look into this now.
Wombles
Wombles
10,808
11,132
SW England
Van Conversion
A few years now
Have emailed & will update the thread when (hopefully) the discount code is working again.
UPDATE - have had a reply & should get code working again later today :) Will check & post once sorted.
252
263
WORCESTER
Autotrail 660 merc
SINCE 2012
Code is working just bought one.
No more asking misses to hold pipe.:)
