Help What Are These Called? (3 Viewers)
32143
Hi does anyone know what these vent things are called, it's where our hot air comes out to heat the van, trying to find them online to replace one as Boston stuck her paw in it and the flap part broke off!
Thanks you
Lin
Nov 30, 2009
6,548
149,013
Pickering
PVC the PUG
Heating vents. Ralph bought a few for our conversion.
Puddleduck
12,387
44,009
Scottish Borders
Without at present
On and off for many years.
Or even an air outlet with flap valve.
Looks like they are easy enough to find and not too expensive.
32143
Brilliant, they look like the thing, will get one ordered and sent to my parents.
MH company said £40 thought was a bit steep for a bit of plastic.
Thank you :)
32143
This might help :) It's a blown air outlet.
Our Grandson parks his toy cars in ours if we don't watch him like hawks.
Brill thanks. I'm not sure what Boston was expecting to find in it :)
Reactions: SMB
keith
3,421
1,864
Ecclefechan
Autocruise Starseeker
Thank you :)
£40 ??? they had to be joking, or mistaken of what you wanted.
Jun 30, 2010
7,925
27,236
1992 VW Auto sleeper Mono
Since 2005 this time
C A K tanks sell 'em Part # G-EN under ELEC AIR HEATER,BLOWN AIR DUCTING AND GAS ACCESS,
Order line 0844 414 2324
www.caktanks.com
32,673
66,645
Are you sure it's actually broken and hasn't just come out as they are only held in by a small spring I believe.
32143
I think it's the spring that we have lost, got the flap and when compared to other one it's missing a bit of metal. As they seem to be cheap enough will get another and couple of spares as well.
Lin
32143
I emailed same pic and said Boston had put her paw in and the flap had come off, maybe they think it's a bigger job, Nige took it off and it just screws back on again, the pipe is still in position with a plastic thing with a thread, to us looks like a simple swap of the front part. :)
32143
Any way thanks guys, and I now have a few companies saved on my phone for any other parts we need in the future, and I'm sure there will be plenty more :)
Jun 30, 2010
7,925
27,236
If you phone C A K Tanks ask 'em for a catalogue, All sorts of stuff & nic nacs to make your life more comfortable
Apr 11, 2015
5,420
55,302
hull
Laika Ecovip 300
O'Learys dunswell near hull
oops where to get not what they are called.
32,673
66,645
11,932
9,097
When we fit them we always pull one of the vent flaps off --that way you always have one open to allow heat out so the heater does not overheat ---They simply screw off from the back -pull out pipe -change it for one that you always can leave open
terry
Nov 30, 2009
6,548
149,013
Pickering
PVC the PUG
Trouble with them is, they aren't directional - and it depends where you need the heat, doesn't it? LOL
If there the ones like ours you twist the whole thing around . So it blows up , down or from one side to the other.
32,673
66,645
That's for the OP to decide if they are suitable, I just gave an alternative to the flap ones - at least the dog wouldn't be able to get his paw in them!
32143
Generally if use the heating it's to dry the dogs so floor direction fine with us. Will do further checking on return to UK. Now I've seen what's out there fancy some chrome one :)
