Help wanted with Huawei 5372 (2 Viewers)
Riverbankannie
Riverbankannie
10,594
61,964
Bristol
IH 630 RL PVC
Well if you have one and don't need to power it I won't ignore, I am sure you must be correct. I wonder if it takes power from the Mifi unit?
@Minxy Girl do you know?
32,699
66,728
Some aerials do have built in powered boosters I believe whereas others are just as DBK has said and are 'bits of wire' (a bit more technical than that but it explains it well!). Some will probably work on batteries and others may have an external power source but I'm not aware of any that would take the power from the MIFI unit itself.
11,958
16,575
A mifi transmits and receives. 10W is the maximum RF power that the antenna can accept from the mifi transmitter (which will actually output less than 5W anyway).
18,043
48,198
Thanks, I suddenly thought I was losing my marbles!
Riverbankannie
Riverbankannie
10,594
61,964
Bristol
IH 630 RL PVC
@DBK Have found the Netgear one for £30 on Amazon.
I think I need to return to an earlier question of mine about connecting the Huawei to an existing wifi network. I can see how I would not need to do it at home but if I was on a campsite with wifi that had a poor signal to the pitch, could I use the Huawei with the antenna to pick up a better signal. That is, not use any of my 3 data. Do I have to use the app to make the Mifi device pick up the wifi signal instead of 3/4 G?
18,043
48,198
To answer your last question first, yes, you can select wifi in the app. I forget how exactly but that's how to do it. However, it doesn't act as a booster and as far as I am aware it doesn't use the external antenna, that's for broadband only, but its own internal wifi antenna. I've tried doing this a few times and could never get a better wifi signal by going through the mifi. To pick up a wifi signal from a distance there is only one way - to use a booster.
But by all means give it a try. If you have a home network, walk outside and see how your phone can pick it up then try doing it through the mifi - I don't expect you will see any difference but who knows? You could of course try using it as a repeater - put the mifi on a window ledge where it can pick up the home wifi then sit outside and try and log into the mifi.
Riverbankannie
Riverbankannie
10,594
61,964
Bristol
IH 630 RL PVC
Now I'm lost again! There is a difference between wifi signals and broadband signals ? And the antenna is just to boost (get a better signal) for broadband (and by broadband you mean 3G and/or 4 G).
I do understand about repeaters. I have set one up at home to extend the home wifi out to shed so hubby can watch SKY on his iPad.
(n)
18,043
48,198
(n)
By broadband I meant the mobile phone signal (3g/4g etc), sorry for any confusion caused by introducing another term. :)
At the risk of causing more confusion there isn't any fundamental difference between wifi and broadband (phone) signals except the phone signals run at a much higher frequency, typically one or two thousand megahertz compared to a typical wifi signal of around two megahertz.
But this frequency difference is why one aerial can't do a good job for both. It needs to be designed for one or the other.
GJH
29,450
38,827
None, now sold
2006 to 2022
(n)
DBK posted whilst I was typing but I'll post this anyway to add to his post.
To put it simply, broadband means fast Internet as opposed to old, slow, dial up access. Broadband service can be via a landline/cable or mobile phone network.
A MiFi device connects to a mobile network and a fixed (wired) modem/hub to the landline/cable.
WiFi is the signal emitted by MiFi or modem/hub and is what devices like laptops and tablets connect to.
Antennae boost the capability of devices to pick up a strong signal - MiFi a mobile phone signal and laptops/tablets a WiFi signal.
Bart
3,188
1,398
Northern Ireland
Boxer L4H2 van build
Since 2016
Thanks DBK this answers my question about needing 1 or 2 aerials... , i would say for me if would prob be more important to have a decent wifi aerial , as most of the time i can get a phone signal in the UK,, mind you ive no idea what its like in Europe , is that a totally different kettle of fish ?? is the phone 3g/4g signal there rubbish ?
18,043
48,198
I'm not aware of any specific wifi aerial for a MiFi, they use their own internal ones, or at least all the ones I know of do.
For boosting wifi there is only one way I know and that is to buy a wifi booster. I made my own but it still cost over £100 though if you use a laptop with an ethernet connection you could do something for about £45. Alternatively, again for laptops, you can get a USB aerial, something like this. http://www.yachtingsoftware.com/usb...YBddyhJk0vYJW5eadhKimPkzDh65KNttRwaApbG8P8HAQ
A lot cheaper but the gain isn't brilliant with that particular model. Others may be better.
Phone coverage in Europe is generally excellent in my experience. It may not be fast with say a Three sim but you should be able to connect almost anywhere.
Riverbankannie
Riverbankannie
10,594
61,964
Bristol
IH 630 RL PVC
image.gif I didn't realise about the different frequencies...
Thanks @DBK and @GJH. Things becoming clearer now.
Glad to be of service to @Bart as well.
Margaritaman
270
395
East Yorkshire
Low Profile C Class
Can you see anything on the screen which shows what address it is using? I've just had a quick look at the 5372 instruction manual and it says if something else on the network is already using 192.168.8.1 it will find another address - but this should be visible on the LCD screen.
My E5573 from THREE is on 192.168.1.1 too Thanks
Oct 30, 2010
4,256
20,707
Suffolk or France or ........
A Class Carthago Chic
Since 2008
Mobile 3g/4g is rubbish over most of rural Britain (certainly here in Suffolk).
Just been all around France and had excellent 3g reception everywhere, even high in the Pyrenees and the wild hills of the Central Massif.
Richard.
Bart
3,188
1,398
Northern Ireland
Since 2016
Yip same here
Richard.
Thanks , good to know :)
