Help required sourcing part (1 Viewer)
haganap
12,760
26,463
planet earth
Niesman+Bischoff 79e
I'm an oldbie MH number 10
On my far superior well built Besacar motorhome I have sprung a leak. Don't worry Terry the floors still dry. But the hose from the tap to the boiler fits in to a t piece and the hot hose has due to some rubbing got a little hole in it. I need new pipe and connectors but can't seem to find them?
Being a Nurse, Intend to operate on the problem adn re-route it doing a better job than the original.... any one know where I can get the hose and t piece please? I have to of course dismantle the bed to carry out this task.
Oh buy the way, Im too busy to call Glen from Jon cross :winky:
aba
2,775
1,112
yorkshire
dec 2009
A picture of said items would help no end as there must be hundreds of different T connectors.:winky:
Try cak tanks they do pipe and fittings.
haganap
haganap
12,760
26,463
planet earth
ive identified the things as being called John Guest
wasp
1,724
18,180
Warsop
None gone caravannin
Haggers you need some 12 mm speedfit fittings they also do a blue or red pipe some plumbers merchants stock em but not all, I got some on me van but am in Mansfield
Feb 24, 2013
13,090
101,510
Bolsover, Derbyshire
Hymer S800
not long enough
Paul won't mind you popping over, he will even stay up to meet you, or leave MH open if you might arrive after he has gone to bed :thumb:
wasp
1,724
18,180
Warsop
I don`t know wot area he lives in
haganap
haganap
12,760
26,463
planet earth
Thanks Wasp, there just the kiddies. Im after a two way divider apparantly, located on ebay, but maybe Ill give Glen from John Cross a ring in the morning and order it from there.
Thanks for all your help guys, and BTW im away this weekend in Glossop area, so if you see me leaking water, it's not my waste left open, its just clean warm natural water so hold your horses.
wasp
1,724
18,180
Warsop
Had you been closer I would have met up and let you have the bits.:thumb::thumb::thumb::thumb::thumb:
jonandshell
5,476
8,299
Not got one!
Only 12mm?!
Pah! Our continental van uses 14mm!!!!!:reel::reel:
Hope you get her fixed Paul! Tara wouldn't like wet paws!::bigsmile:
Ridgeway
3,666
6,176
Lausanne
NiBi Arto 85E
Or call in at Glossop Caravans at the weekend and see if they have them in stock ?
Osmotics UK will have a few 1000 likely as they supply me with plenty of them:Smile:
old-mo
Extra Special
16,343
93,692
Weymouth. Dorset...
Nearly aint got one.
Caravan & motorhome 45 + yrs
Clean round the leak....
And a Blow Lamp and plumbers metal usually does the trick... :thumb:
:RollEyes::winky::ROFLMAO:
haganap
haganap
12,760
26,463
planet earth
Only 12mm?!
Dont say that John,,,, Im only thinking there 12 mm:Eeek:
Cheer,s Mo your a star., Ill try that first before I leave in the morning :thumb:
wasp
1,724
18,180
Warsop
They are 12 mm and red :Smile::Smile::Smile:
17,635
43,370
Thanks for all your help guys, and BTW im away this weekend in Glossop area, so [HI]if you see me leaking water[/HI], it's not my waste left open, its just clean [HI]warm natural water[/HI] so hold your horses.
as a nurse get yourself down to the urology department. I had that problem and they fixed me up. just dont look at the size of the inspection camera:Eeek:
jonandshell
5,476
8,299
Not got one!
If your pipes are 14mm outside diameter Paul, you can use domestic push fit couplings from Screwfix.
They are cheaper because they have no mention of motorhome on the packet!::bigsmile:
haganap
haganap
12,760
26,463
planet earth
Thanks a bunch Mo
I took your advice Mo and it looks like my weekend away is bloody ruined :Angry:
Anyone know any fire damage restorers? or do you think its a right off?
Bluemooner
1,723
8,074
Ribble Valley
Dreamseeker Fifth Wheel
4 years
I see you managed to get rid of the streaks
Ash
Trader - Service & Repairs
788
217
Chapel st Leonard's. Lincolnshire
They are 12mm in your van Paul I will have some parts with me at Stratford if you need them :thumb: if you need them before you camping shop should have them in stock,
