my truma on off pull switch wont stay up and closed, so water would drain out all the time? any clues???
Put a clothes peg round the red button in the up position and then run up the heating, once hot it should stay up. If not it is faulty.Yes, probably too cold for the frost protection valve to stay closed at the moment
Try running the boiler for 20 mins, assuming you can run your model dry, you can most of them
When you click on “Quote” you should see to the left of the area for text below it is “Attach files” click then browse to the fileHow do u post a pic??
If you do have peg keeping the dump valve closed then keep the heating at a low setting if need be if there is any risk of the temperature dropping down to 4 or less. Better to use a bit of extra gas than risk permanent damage to the heaterThat drain valve is also an automatic frost protection valve, that is there to prevent expensive frost damage to the water heater. So be very careful if you use a clothes peg to keep it closed. It dumps the water at about 4 degrees, so there is quite a safety margin, but best not to leave the peg on if the weather turns really frosty.
It needs a 12V supply to stay closed. It automatically opens if the 12V supply fails. Typically it's wired on the same circuit as the electric step, so if the step is not working that's a clue to possible power failure.
