help please. (1 Viewer)
Feb 22, 2011
9,784
20,147
Newcastle under Lyme
Hymer B544 A Class
Since 2015
Yes, probably too cold for the frost protection valve to stay closed at the moment
Try running the boiler for 20 mins, assuming you can run your model dry, you can most of them
1,124
1,123
Sutton Coldfield but East Yorkshire man at heart
Elddis Autoquest155
Since 2018
Put a clothes peg round the red button in the up position and then run up the heating, once hot it should stay up. If not it is faulty.
8,632
44,509
Worcestershire
Bailey Adamo 75-4t
March 2018
At the bottom of the reply box is a button called attach files. Hit that and then locate the photo on your computer.
Sue coulson
May 22, 2019
321
113
Falmouth cornwall
Pilote p650
3 years
Done it
8,632
44,509
Worcestershire
Bailey Adamo 75-4t
March 2018
Somebody will recognise it.
It looks electrically operated so may not have 12v to it. Fuse?
If not, my guess is that it’s too cold to stay set so maybe give it a blast with a hairdryer and try again?
Tombola
4,817
15,699
Merseyside
Rapido 8094DF
Since 2004
if its getting power, the stick a hairdryer on it then put your heater on low warm
6,872
7,991
Manchester
A class Hymer
Since the 80s
That drain valve is also an automatic frost protection valve, that is there to prevent expensive frost damage to the water heater. So be very careful if you use a clothes peg to keep it closed. It dumps the water at about 4 degrees, so there is quite a safety margin, but best not to leave the peg on if the weather turns really frosty.
It needs a 12V supply to stay closed. It automatically opens if the 12V supply fails. Typically it's wired on the same circuit as the electric step, so if the step is not working that's a clue to possible power failure.
1,124
1,123
Elddis Autoquest155
Since 2018
If you do have peg keeping the dump valve closed then keep the heating at a low setting if need be if there is any risk of the temperature dropping down to 4 or less. Better to use a bit of extra gas than risk permanent damage to the heater
