Help please damage to our motor home (1 Viewer)
Jun 29, 2015
3,483
57,532
Southampton
caravan (for now)
on and off since 1984
Hi I hope someone is able to help, as this is my fault. When loading items into the MH
I did the damage. I need to find some corner cladding to cover it up. Any advice welcome.
Thank You in advance!
Jul 29, 2013
9,071
18,565
Salisbury
Hymer B678DL A class
Look like you could take that out and replace,trying to repair it would probably not look to good as it's a very thin veneer on MDF.As Brian said sticky plastic but probably need to fill damage out flush so that it does not show through or a nice piece of stainless angle fitted on would look good also save you damaging it again.
peter marshall
2,466
1,704
Cleveleys,Lancashire
Low Line
9 Years
If it's the same edging both side's any replacement or cover over would look a lot better if both sides were the same. try B n Q they sell all sorts of stuff or you local double glazer suppliers they have all sorts of covers. Pete
Gellyneck
9,245
18,337
More than toes wet now!
Just another thought.
If you can remove the damaged piece is it "reversible" with the damaged corner going to the inside?
Odd job
Jun 29, 2015
3,483
57,532
Southampton
caravan (for now)
It looks like an edge but is part of the side panel so cannot be moved. I have found some corner strips but not the right size. I think the best idea may be sticky back plastic it can be made to fit
Jan 28, 2008
10,121
18,386
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
if its a place its likley to get damaged again you could cover it with a metal angle strip and do other side to match
Odd job
Jun 29, 2015
3,483
57,532
Southampton
caravan (for now)
If I load it properly it won't get damaged again
kelv
672
895
leicester
Carthago 145
You can get wood effect corner strips just put corner strips in ebay there are lots of colours simple job to glue on once cut to length.
You can also try a local kitchen company who make there own cabinets and see if they have any veneere to match.
R
Robert Clark
I'd suggest giving it a light sand, then prime and paint it black or dark brown to match the metal trim its next to
Jan 2, 2015
2,472
8,630
Cumbria
Burstner Solano t725
since 2014
Presuming that it is MDF with a veneer of plastic type material on it, have a look in the manufacturer's brochure for your MH to see if there is any description of the kitchen or wood trim, ie 'Ash ' finish to the wood. (it looks like Ash to me) then look for Fablon or other sticky backed plastic with the relevant woodgrain and re-cover the whole piece.
Amazon do a similar one at..
Amazon product ASIN B005ERJ7JO
Bear in mind that when you rub it down with sandpaper to get rid of the rough edges, you will probably create a flat spot on the radius that may cause a wrinkle in the material.
Odd job
Jun 29, 2015
3,483
57,532
Southampton
caravan (for now)
Thanks everyone
DanielFord
3,020
3,086
I am on 3G at the mo, and I can't get tags to work. Peter Marshall is quite correct. Both B & Q and Homebase have a section in the timber aisle, where you can buy mouldings. I have purchased this exact moulding, it comes in roughly 6' lengths, rip that one out an replace with the new :D
GWAYGWAY
4,213
3,306
Dover
Hymer ML I 580
4 years
It is more like chipboard with a cardboard printed surface, get a piece of alloy from B&Q and stick it over the corner and cover it all.
petensal
200
196
Lincoln
Overcab
Since Sept 2009
You can get laminate flooring repair kit try eBay, may take a bit of time but do able.
Or maybe try car body wrap vinyl in a contrasting colour.
Odd job
Jun 29, 2015
3,483
57,532
Southampton
caravan (for now)
Thanks for the info. I will have to sort it out now
