ok 2017 ducato 130 no output from the alternator to the engine battery but no ign warning light on ? i have checked with 2 multimeters both showing 12.5 v at the battery engine running,any ideas on where to start to find the problem tia
its the same at 12.5 voltsTry and see what the voltage is between battery 12 + and engine, using the engine as a ground.
hi i will try that in the morning as its raining here and i will have to jack it up first. this is a strange one on me ,i have yet been able to find a wiring diagramAre you able to get at the alternator wiring connections to check they are ok , also I think that the main alternator output may be linked to the starter battery via the starter motor main lead connection and may be worth a look at.
If you do have a jump lead you could also try a temp. connection between the alternator body and a good earth to eliminate a poor alternator earth..
it comes on when i turn the ign on then goes off when i start it upWhen you say no ignition light can you confirm you mean it is not coming on at all.
no just a usual onejust noticed that yours is 2017, so possibly a smart alternator, which complicates things
then check the regulatorno just a usual one
thanks i will get under it in the morning
hi its not a smart alternator but thanksHas it got a smart alternator?
If so 12.5V is fully charged so switch on headlamps etc and see what the volts are take a few readings 10-15mins apart
This suggests the alternator is at least "excited" and "should" be pumping out 13 - 14v DC to the vehicle battery. If it's not, as seems to be the case, then it could well be (as has been said) a bad earth at the alternator or battery and/or a broken regulator on the alternator.it comes on when i turn the ign on then goes off when i start it up
Voltage measured at the battery only 12.05 when off ehu for a few mins then drops down I have not measured the alternator output only at the battery also I have used 2 metersAre you measuring the voltage at the battery or straight on the alternator?
If at the battery and at the alternator it's over 14v that would point to a wiring or earth fault.
Have you checked your meter against another one to make sure its ok?
If the battery is low best not to try starting the engine as you could take out the Airbag ECU.
Sounds like it could be the battery dragging the alternator output down.Voltage measured at the battery only 12.05 when off ehu for a few mins then drops down I have not measured the alternator output only at the battery also I have used 2 meters
