- Jan 28, 2008
- 10,118
- 18,385
- Renalt burstner
- 7 years campers before that
my old talbot suffered from the tank rusting internally and was for ever blocking the filters on the carb inlet
I managed to get a diesel going for a neighbour one cold morning with deodorant (not roll-on) !try starting it on aero start or carb cleaner
Agreed, if theres a spark and no mechanical damage easystart WILL start it....but because its so easy the underlying problem gets overlooked and the engine begins to depend on easystart every time.A warning about "Easystart" type sprays, they are usually ETHER based and can wash the residual oils of the cylinder wall accelerating Wear, if used an a regular basis. Nor is it recommended for use on Diesels with glow plugs, one of the easiest ways to burn them out.
"One off" Emergency starting is likely OK. but prolonged use indicates an underlying issue which needs rectifying.
