Help! Fused 12v socket (4 Viewers)
Mags52
1,433
1,731
Melrose Scottish Borders
Hymer B774
Hi Folks
Oh Help!!!
The 12v socket for the TV has fused and I'm trying to replace the fuse. The instructions for the MH are in German and I can't work out which fuse it is. I'd take them out one at a time but they're under the body and it involves a level of contortionism I don't have.
Any idea what the German for 12v socket is?
It's a Geist touring 75 if that's any help.
Mags
welsh winger
228
58
Sunny Swansea
swift lifestyle
4 years
12 volt socket = 12 Volt Steckdose
I used this site when we had a German van
Nick
Mags52
Mags52
1,433
1,731
Hymer B774
Wivvy's Dad - I know it isn't working when it was just a short time ago so I assume it's the fuse.
Thanks for the translations folks.
I'm going under into the belly of the best ... :RollEyes:
wivvy's dad
3,205
1,795
48.066895,12.862673
Transit LWB Hi-Top PVC
On and Off since '98
Assume makes an ASS out of U and ME
Mags52
Mags52
1,433
1,731
Hymer B774
Well I may have been making an ass of myself but it worked. TV now works - the fuse was bxxxggered.
Having said that it was a hell of an awkward position to get into. Hope neighbours weren't looking out of the window. :Eeek:
wivvy's dad
3,205
1,795
48.066895,12.862673
Well done, that wasn't so bad was it?
Why did the fuse blow?
Will it do it again?
Do not ASSUME the problem is fixed.............:whatthe:
Mags52
Mags52
1,433
1,731
Hymer B774
I overused an inverter ... 150w. My own fault so I guess I deserve the hanging upside down trying to see through the wrong bit of my varifocals with my bum hanging out the door. Really not a pretty sight.:Blush:
43,348
49,548
what was the fuse size ?
the inverter may be a 150watt continuous/300watt peak jobby so should be on a 25/30amp fuse.
if its 150watt peak it should be on a 15amp fuse.
150watts divided by 12v = 12.5amps ....15amp fuse
why they stick these on a 10amp fag lighter socket beats me :Doh:
you do need to take care with 12v 5amp fused fag lighter type plugs.....i had two melt at Malvern, (one melted the plastic socket as well) both running TV's (one lounge and one bedroom) and both TV's rated at less than 3amps each.
the fuses didn't blow.
I've since upgraded to Hella/DIN sockets/plugs, rated and fused at 10amps each
Mags52
Mags52
1,433
1,731
Hymer B774
Thanks Pappa John,
It was a 10a fuse. Is it ok to put a bigger fuse in then or will that just make it melt?
I was thinking that I shouldn't use the inverter anymore which would be a shame.
43,348
49,548
Thanks Pappa John,
Not really advisable as the wiring will be rated at 10amps...the fuse protects the wiring, not what's plugged in.
so, anything drawing more than 10amps will overload the wiring, possible melting it and causing a fire, if a larger fuse is used.
the fag lighter wiring on my RV is, like most things American, much heavier than need be and the fuse is probably under-rated at 15amps.
you should be OK using the inverter as it is but be careful what you plug in.
generally anything plugged in with a motor or transformer in it will draw a high current at start-up and drop to a steady lower current once started.
