help can't pull toilet cassett out (2 Viewers)
1948
444
49
surrey
hymer A class
since 2010
Light came on toilet cassett so went to open outside toilet door and tried to pull cassett out to empty but cassett just would not slide out. Thought cassett might be too full so mopped out (5 to 10 litre) fluid from hole through toilet seat (not a present job) but cassett till would not slide. Anyone can help please I am new to this I have only empty the cassett once before and it slided out no problem Thanks in advance
444
49
surrey
hymer A class
since 2010
yes, just checked again cassett would only lift slightly (from outside)
wasp
1,724
18,180
Warsop
None gone caravannin
Just check under the pull handle is there a yellow lever catch that holds the cassette in, there is on mine just a thought:thumb::thumb::thumb:
Munchie
8,921
12,581
Camping Les Vigeres
Font Vendôme
As you take hold of the main hand grip, put your fingers under near the bottom and you will find there is a lever you lift to release the cassette. Sorry if this sounds basic but you did say you were new. ::bigsmile:
444
49
surrey
hymer A class
since 2010
Thanks everyone, how stupid of me I did not push the yellow tap to relieve the lock Should have asked before starting mopping up the liquid from the hole !!!!
There you go for senior moment> thanks all of you
XXXX as i was emptying the contains I have a leak coming out from the top of cassett via a small rectangular hole approx 3mm x 6mm Is this normal or have I got something missing???
Munchie
8,921
12,581
Camping Les Vigeres
Font Vendôme
Not sure about the hole but it should not leak. Sometimes there is a small amount of water under the slide if someone has flushed and left it open long enough to drain the loo. :Eeek:
Bet you won't forget that lever again in a hurry. :ROFLMAO:
Sorry couldn't resist. :Doh:
JAY KAY
24
Shotgate, Essex
This is a breather and tends to leak when tank is nearly full, best to empty cassette daily.
John
derekfaeberwick
1,035
9
Berwick
Low Profile
9 Years
John
Not really, just take care and mind the light.
Use bio washing tablets and then you'll cut costs and you can 'dump' in toilets in small villages without upsetting the 'BIOS' in their cess tanks.
Munchie
8,921
12,581
Camping Les Vigeres
Font Vendôme
He means to keep an eye on the light and empty as soon as it comes on. Personally I empty every day as I don't fancy getting up in the middle of the night to do it. :Eeek:
Judge Mental
Sep 2, 2009
6,650
5,883
Sarth London
Possl 636 FR panel van
1994 and beyond...
a tip I think I read on here is, if touring and worrying a bit re emptying, fill an empty detergent/cleaner spray bottle with water, and instead of using loads of water to flush just use spray.......:winky:
Douglas
2,835
400
South Wales,
Watching for the light to see if the cassette is full can be problematic, failure of the indicator light is a very common problem, instead I recommend using a torch and LOOKING!!!
Doug...
Welsh girl
3,658
3,036
Globecar
Bio washing tabs, instead of the normal elsan fluid? I use the green organic fluid now but do you use washing tabs instead because that would save me a lot if you could?
Spacerunner
607
197
Hampshire
For future reference if your cassette is stuck and over full the way to overcome this is by unfolding the spout and hold a bucket underneath and remove the yellow(?) cap.
Excess content will then drain straight into the bucket and is a much easier and pleasanter (?) job.
Denny
55
Dethleffs
Since May 2008
Sorry to admit it but this ' Back To Basics' post really made me smile !
Thanks for that.
Denny. :Smile:
neilmac
217
UK, France & Spain
2nd year
Think you can use various types of bio - we've been using cheapo Sainsburys own bio washing liquid (half cassette capful per use), works very well. Certainly won't be going back to very expensive Thetford/Elsan products :Smile:
dshague
996
302
VAN CONVERSION
20 years
its nice to see a post like this .it reminds us all that we all have been there .
how about telling us all the daft things we have done when new to motorhomes
we have drove of with electric still connected to van .dropped the cassette cap down a man hole that was fun with a bit of wire fishing it out of a six foot hole :cry:
