Hella reverse lights
Apr 24, 2022
5
11
Bolton, Lancs
Swift Sundance 580PR
At the moment I'm trying to replace a faulty Hella reversing light on my Swift Sundance 580 PR. 2010.
The lamp has 2 bolts holding it in place. The problem I have is accessing the nuts on the other side. Looking from underneath they're above the floor and from the inside there is no obvious access. Anyone any ideas 🤔. Tha
Can you trace the orange and white wires on the inside.
There may be a trim panel across the back wall needs removing
Hi the rear panel is solid, no access area, bit of a design fault I think, and looking at it more carefully you can get to the light from underneath but requires removing a panel and a ton of underseal! All that being said I have managed to get the light working again (yeah). A lot of wd40 and a really small piece of emery paper cleaning all the contacts 🙂.
Thanks again for your advice 👍
