Heating in Winter. (1 Viewer)
Aug 15, 2014
2,500
3,187
Exiled in Yorkshire
Pilote 600L
Since 2006
I have never used the van in the cold of Winter. Arriving at a destination, wild camping no EHU etc and it is minus whatever outside how can you heat the van if you feel that the boiler could have frozen, how can you tell it is safe to switch it on.
If I have pegged the automatic boiler "dump" valve closed over night to save all the water draining away am I risking bursting the boiler !!
I have no tank heating fitted.
Should I simply stay at home :whistle:
Many thanks.
bigtwin
4,729
8,959
Derby
Concorde
Since 2006
Looks as though you have a Hymer.
Is it blown air, or Alde heating that you have?
If the latter, does it have the heat exchanger fitted that allows the use of engine heat to heat the habitation area en-route to your destination. If so, it’s unlikely that you’d end up with anything frozen.
Ian
TUCANO
Aug 15, 2014
2,500
3,187
Exiled in Yorkshire
Pilote 600L
Since 2006
Many thanks for a quick reply there, blown air only in my Hymer (y)
Abacist
3,509
9,371
Devon
N & B Tag Axle
since 2013
The boiler is inside the vehicle not underneath where the cold water tank is so that will be the first to freeze. Surely you could run the hot tap before putting on the boiler and if you have water then the boiler is not frozen and you can light it - surely or am I missing something?
Yes and once lit keep it going as above!
Northernraider
25,893
153,064
On the sofa ....
Hymer 654
On and off since 95
His water tank is inside also ...same as mine inside double floor.
Nov 18, 2011
11,826
42,599
Planet Earth
A van
Over 25 year's
Chines diesel hetter ruining on cero
Work a treet cheep as chips as
to run.
Had my one since last winter
No problem
Bill
Nov 18, 2011
11,826
42,599
Planet Earth
A van
Over 25 year's
Many thanks.
We use our van all year round frost protection heeter when at home and and un occupied the but if occupied internal temp of the van Shuld not drop below freezing if you have pipes running through cupboards you worried abut just wedg then open a bit so warm air gets in
Bill
Sep 12, 2016
2,251
4,987
Chesterfield England Tellus 3
Lunar Roadstar 800
6 years
We have a standard blown air heater no liquid in the central heating
The hot water tank is inside the double floor of the vehicle so not open to the outside and doesn't have an automatic dump valve but in all our years we have never had a freeze up as the water heater is always on as we use our van 365 even on the drive it becomes another room of the house giving me a peaceful art studio
two
Aug 4, 2011
4,818
4,426
West Midlands
A-Class Fiat
Many thanks.
Fear not. There are many less knowledgeable than you who go out in winter and survive! How? Because they are most unlikely to suffer internal freezing if they are comfortable inside.
D
DL42846
I would never peg the dump valve. I do turn off the power to the water pump so if the dump valve does open then I only loose the water in the boiler and not the whole water tank. Once on site I then turn on the boiler and open the power to the water pump. When driving in very cold conditions ( -8c to -15c) I have had a situation where the boiler dump valve opens even though its nice and warm from the vans engine heating system. The back of the van can still get very cold when rolling along on the road in the above temperatures. I have on occasions driven the MH with the boiler on and the heating system working.
