Have done this high low and med but still cold airAdjust the temp in the control panel
We had hot water when in use, does the heating have to run via the hot waterHave you got hot water, appreciate it’s different
I have a 1996 640 and it does have electric built into the heater. Not all do but if you don't you wont have the controller.
Firstly it only works on EHU but you know that.
There is a separate switch on the wall somewhere near the controller to turn on the power, mine is to the left of the wardrobe on the wall.
The controller has 4 positions 2kw at the top then Off then 500 watts then 1000 watts. Also build in to the same dial and easily missed is the the thermostat ring. If it's not turned up high enough the heating won't come on.
The fan control on the heater is separate and uses 12v.
If you need to now anything else about you van let me know, I've had mine 5 years.
Yes it comesThat's the original controller apologies I described the newer one, I had forgotten I changed mine a few years ago. Too much sun this afternoon
The top left hand fused switch in your photo supplies the power to the electric part of the heater. Does the little red light come on when you switch it on?
Then your trip is ok and the fuse is ok. I can't remember how my old heater worked I'm afraid, can you put up a photo of the top of the heater to remind me what controls you have?
