Habitation door (1 Viewer)
Oct 2, 2011
864
571
Since 2011
Hi, the MH came with an extinguisher fitted, on the side of the overhead locker to the left of the door. The type that was fitted just hung on a holder but would fall off if not removed before driving. You can guess how I found that out. I had wondered what the little dents in the bottom 18" of the door were. The little dents don't looke much so not concerned about them. What is a bit more of a concern is the bottom of the door doesn't shut fully. It looks like having been hit a few times has bent it or the hinge slightly. Any advice on how to rectify this? Is it just a case of carefully knocking it back into shape?
Gordon:thumb:
Swiftroy1
159
151
Bedfordshire
Hi, the bottom of my habitation door fitted badly too. To rectify it, I removed the door from the hinges as they were only screwed. I then drilled the hinge rivets carefully from the frame and examined the hinges. I found that the bottom hinge had been bent slightly comparing it to the other hinge. This wasn't visible till I laid one over the other. I then bent the offending hinge straight and refitted them. The problem was solved. I hope this helps.
Roy
Jul 28, 2010
1,710
617
The world
Small car
Roy
SOUNDS A LITTLE MORE THAN A DIY JOB :whatthe: not sure I COULD DO THAT :Eeek:
GJH
29,450
38,827
None, now sold
2006 to 2022
I think it could be a "feature" of some Explorer vans that the lower hinge is either mounted slightly wrongly or bends. Our hab door used to creak quite a bit and then, eventually, the hinge broke.
I sourced a new hinge from Marcle Leisure and fixed it myself. Not as daunting a job as I first thought, thanks to advice from other Funsters. See Link Removed from June last year.
Touchwood
772
733
NE England
Compass Avantgarde 140
5 years and learning
Gordon:thumb:
Hi Gordon, I have the same door issue on my Avantgarde 400 RL (2002 so presumably pretty identical to yours)
At the moment there is no actual gap, the door seals but the lower part is definitely not as snug as the upper. I'd be glad to hear of any solution you've found, have you tried removing and checking hinges as has been suggested?
Mike
11,932
9,092
Hi you can bend the hinges back using a block of wood and a hammer :thumb::Eeek:
terry
Touchwood
772
733
NE England
terry
Errm - for someone with my aptitude for DIY that sounds like a recipe for disaster - a bit like [ame="http://www.youtube.com/watch?v=8g_GeQR8fJo"]this[/ame] ?
11,932
9,092
Errm - for someone with my aptitude for DIY that sounds like a recipe for disaster - a bit like this ?
Hi TW you are not kidding me ::bigsmile: it says you are a heating engineer -you know exactly how to yeld a hammer :ROFLMAO:
terry
Touchwood
772
733
NE England
terry
He He - maybe Terry - but in my book a hammer (or engineer's reciprocating tolerance adjuster, to give it its technical name) is for breaking things, not fixing 'em! :winky:
gordoncbrown
Oct 2, 2011
864
571
Since 2011
Looking good. Tried a bit of gentle persuasion and the hinge side is spot on. Still a bit out somewhere but looking at the door it looks. Bit off true after all the bumps with the extinguisher. Next step is to tackle that.:thumb:
